Posted By ronmar on 25 Feb 2017 02:03 PM
The human waste that goes down a toilet is a very small fraction of the volume of the liquid waste produced by the laundry, sinks, dishwasher, shower/tub and yes a flush toilet...
I don't see you having a building department approved residence with running water that does not incorporate a drain field or mound for effluent processing...
You are assuming that all of the liquid waste will be going into the OSTDS. Depending on the state's greywater rules, the only drains that have to go into the OSTDS are toilets, urinals, floor drains, dishwashers, and the kitchen sink. The rest
may be fed into a greywater system. This is adding another layer of complexity to the project, of course.
Just for fun, here's a configuration that eliminates any need for a drain field and theoretically could be contained in a basement (or buried under the basement floor). It would certainly require a very committed person to conform to the lifestyle required by such a system. Of course, your AHJ's rules may vary...
1. Eliminate some liquid effluent sources completely:
a. No dishwasher - wash dishes by hand.
b. No clothes washing machine - wash by hand.
c. Composting toilet.
d. Waterless urinal.
e. No floor drains.
2. Implement a greywater system for the following sources classified (in most jurisdictions) as such:
a. Shower/bath.
b. Lavatory.
3. Use an ATU (aerobic treatment unit) for the only remaining source classified as blackwater:
a. Kitchen sink.
The greywater and ATU effluent, after whatever filtration/decontamination steps are required, can be discharged directly to the world in various ways but drip irrrigation is the most logical. Assuming you have a healthy gut microbiome and aren't excreting vast populations of nasty critters, the small volume of effluent from each system can be diluted with a rainwater collection system that should easily and consistently keep your results from the required periodic lab testing well below the critical levels.
Practical? Of course not. Stimulating to design and implement? Definitely.
