Posted By Bob I on 10 Feb 2017 07:16 AM
that should say "tape" the joints, using a long lasting acrylic tape such as 3M 8067.
Long lasting? No such thing for room temp cures more less weathered cured film adhesives (best if FOD free hot bonded under pressure most don't do), never has been never will be, especially acrylic bonded to wood. When they thermally cycle, and see other life cycle fatigue from building dynamics the adhesives fail in a short time. The only way around this is in a factory autoclave with elevated pressure and temp cure ~ 250 - 350F under vacuum pressure(bagged or plate) in a clean room that does not produce voids or delams, like OSB/Plywood, then metal bonds will see 30 yrs on average, acrylics 5-15 yrs. Your welcome to look at the life cycle 3M data for lap tension/shear of this "long lasting" adhesive I doubt you find and post it?
I think this whole industry be better off if builders focused on the many challenges of robust low cost building and left the design to engineers.
Rob, R5 CS walls, 5 ACH @50 ~ $100 yr diff R 10 vs R31 roof, R7 ish walls. If you decrease ACH I posted the values and if you give me your window areas per facade old/new u-value and SHGC, door sizes and direction the front is facing I can tell you more. Without more in the wall and less in ACH I doubt you see a whole lot of differences.
Interesting how consumed energy gets exponentially lower @ < 1 ACH. But, there is a price to be paid.
