Ok, thanks Dana! Yeah, I think it will work, and it's good to know you can position the core anywhere in the length of the tube. I assume it doesn't slide 'down' the tube with vibration/use, given they say to have the tube pointing slightly downward to the outside, for any condensation.
I'm pretty confident I'll fur over the polyiso with the 2x3, as the 1.5" thick strip would allow me to use 18 cu in receptacle boxes, without having to cut the foam. I still have to figure out how run the wiring and stay > 1.25" from the surface of the furring strip. I saw these:
http://www.viperstrap.com/ which would work well to attach the wiring to the surface of the foam, if I am able to confirm they'll meet code. Where I need to run some half-hot plugs with 14-3, I'd likely have to either add another 1/4" furring to the wall, cut the foam to route the wire, or use EMT (but then I would probably have to ground the EMT).
