Concrete Floor Options
Last Post 10 Dec 2018 07:40 PM by Dilettante. 1 Replies.
SexyWallpaperUser is Offline
10 Dec 2018 01:04 AM
Hey all. I've got a concrete floor in the basement that I need some help with. The floor currently has a few coats of Drylok white masonry paint on it which was put down since moisture seeps up into the concrete in a few spots at a very slow rate. Never puddles, just dampens. Drylok has kept the floor dry, but chips away in heavy foot traffic areas, and creates white dust which contains silica when we drag heavy things along the floor. Ideally we'd remove all walls and equipment from the basement, remove the paint, and have the concrete slab professionally repaired and smoothed out. That's not an option though, since we have a small legal grow down there, as well as a bit of a workshop area. So could I epoxy over the drylok? I'm thinking of cleaning the drylok real well (vacuum, mop, bristle, etc), putting a new coat or two down, then epoxying over this. I don't know anything about epoxy, however, like using a 2-part vs a 1-part, good brands, proper methods, etc. Any advice?
DilettanteUser is Offline
You don't want to SEAL the concrete that way, as you leave it no place to get rid of the excess moisture.
That could lead to hydrostatic issues and heaving.
Would recommend repainting it.
Then put down dimple mat and a plywood subfloor atop that. You can then throw down a finish flooring atop that.
This way, the concrete can still dry properly, but you're not walking directly on it.
