Attic Insulation - R60 combo of Fiberglass and Cellulose
Last Post 08 Jan 2019 07:43 PM by ian_upton. 2 Replies.
ian_uptonUser is Offline
08 Jan 2019 04:37 PM
New construction in Michigan Zone 5. I am being told that for cold weather builds, that they install craft faced fiberglass batts between the 24" O.C. trusses to allow for some heat to be put into the building for drywall install. After drywall is installed, would go back into attic to air seal (pull back fiberglass, air seal, replace fiberglass) and cover with sufficient blown cellulose to attain R60. This seemed odd to me. Is this normal protocol? Anything specific to be worried about with combo of fiberglass and cellulose? Thanks in advance. Ian.
1840's Timberframe House
- Air sealed attics + R60 cellulose
- 2 part foam in crawl space and band joist
08 Jan 2019 07:00 PM
I've not heard of that being done, but it can make some sense if it's cold outside.
It's fine to just blow cellulose on top of the fiberglass- no worries whatsoever.
Thanks Dana. I was hoping you would respond.
People Online People Online: Visitors Visitors: 236 Members Members: 0 Total Total: 236
