Idiot Builds a Home
Last Post 21 Mar 2026 10:09 PM by Kipring. 105 Replies.
Page 3 of 6 << < 12345 > >>
KipringUser is Offline
30 Oct 2021 05:20 PM
Almost ready for the pour:
smartwallUser is Offline
31 Oct 2021 01:22 PM
A tip. If your build is going to take you awhile, use some wrong color house paint from the homarama on your 2x4 bracing. It will keep from twisting. Same thing for the deck sheathing.
10 Nov 2021 02:20 PM
Oye, thank you.  Would have used this tip sooner.
10 Nov 2021 11:57 PM
I've been throwing it out there for years, ever since I began using Zonts and Zuckles. With Z&Z's you can brace from the outside which leaves the inside free to pour your rat slab at the same time as your walls. Saves time and money. One pump rental for the whole thing. For the floor system I use either Watkins hanger or the Burmon hangers. Easier than the Simpson system.
sailawayrbUser is Offline
11 Nov 2021 02:25 AM
My tip...listen to Smartwall...
15 Nov 2021 12:06 AM
My wife doesn't .
15 Nov 2021 07:03 PM
You had best listen to your wife...happy wife...happy life!
16 Nov 2021 05:36 PM
That's what I've been told.
newbostonconstUser is Offline
17 Nov 2021 11:50 AM
I call BS....It is a trap....it is the wife's job to be happy not mine...
17 Nov 2021 04:23 PM
Touche'. I agree.
02 Mar 2023 09:40 PM
It's been a long while, but still at it.
The horrible contractor that I was utilizing for the pours and agreed to do the final lift abandoned the project. I had to finish the 2nd floor myself and do the pumping myself. Lots to post but now I feel I'm finally at a good place in the project.
02 Mar 2023 10:04 PM
Setting in the beam for the 2nd Floor
02 Mar 2023 10:07 PM
Setting up the i-joists.
03 Mar 2023 03:02 AM
Master Bedroom Framing
03 Mar 2023 03:03 AM
2nd Floor subfloor down
03 Mar 2023 03:04 AM
Window Bucks and 2nd Floor Stacking
03 Mar 2023 03:08 AM
Easy part done, time to do scaffolding and the high wall
03 Mar 2023 03:11 AM
By the way - I'm terrified of heights
03 Mar 2023 03:27 AM
I don't have many good pictures of pump day.... it was close to a failure.
My fault entirely from pushing each weekend trying to do as much as possible without slowing down more often to think through.
Had a serious blowout at the INSIDE corner of the 45 degree, going into the master bedroom. I had screwed the trusses into the form work but didn't add additional support between the webs of the trusses. About a yard of concrete, yes almost a full yard poured out. It was a mess to clean but it was salvaged and used as part of the patio pour.
After that issue the windows were the next to...ooze... just those three large openings so close together, they didn't have enough connections between the buck and the form so the concrete oozed a bit. We paused and shot several more screws and a couple of 2x4's across them just to be safe and then finished the pumping.
Oh and that was only half of the issues. The boom pump operator was older... eyes weren't too good... so while I was up high holding the tube, he managed to yank it out of my hands more than a few times and pepper me with concrete. Guys that have done this know what I mean when I say that stuff hits you... it isn't water (duh) and it has force coming out. Not exactly fun when you are up on scaffolding getting slapped in the face with a tube of crete.
And the icing on the cake... did I mention the boom operator's eyes weren't too good? He managed to hit the power line and generate arcs all around the boom pump, creating several fires. After we doused the fires with dirt and thought the show was over, the operator was looking carefully over his rig. BOOM, one of his tires he was standing near burst, sending him flying several feet. His arm was cut up from the rubber and steel, he couldn't hear, and he looked like he had just climbed down a chimney. Once we were able to ascertain he was going to be okay and he gathered his wits - he quit. This was the second time in as many years hitting a power line - he thought God was letting him know, it was past time to retire. I think he was right.
03 Mar 2023 03:30 AM
Truss Day was my favorite day thus far. Didn't have to do anything dangerous or stressful - just send up the correct trusses in order to the crew.... yeah sub-contracting is where it's at - if you can afford it... but for craning in trusses, not much choice.
People Online People Online: Visitors Visitors: 164 Members Members: 0 Total Total: 164
