Kipring
Kipring
07 Mar 2023 05:07 PM |
Just got most of the membrane installed and here we are. |
Kipring
07 Mar 2023 05:14 PM |
Current Items: - Contracting the Roofer - 2 weeks windows arrive - Cleaning Openings - Applying Seam Sealer - Pouring Front and Rear Door Sills - Installing Hurricane Ties - Cleaning |
EmilyB
13 Mar 2023 08:04 PM |
Wow, what an amazing journey! It's looking really good so far. I hope you keep us updated, I'd love to see the finished product! I'm in the process of building a new, sustainable home that I can rent out as temporary accommodation. With ZERO building experience and knowledge, I've found the whole process extremely difficult. One builder tells me one thing, another builder tells me something totally different. I don't know which way's up anymore! After months of deliberation, I've decided to make things as simple as possible and build a tiny home instead. It was this article that steered me in this direction https://podlife.co.nz/airbnb-invest...iny-house/. It looks like the most viable option, and it's far more affordable than anything I've checked out so far! I'd love to know you're thoughts seeing as you're deep into the build process yourself. |
Kipring
22 Mar 2023 02:24 PM |
Posted By EmilyB on 13 Mar 2023 08:04 PM
That wouldn't be my wheelhouse - I'm building a home for living not utilizing for income or resale. Very different objectives regarding size, quality, materials, etc. |
Kipring
29 Sep 2023 07:52 PM |
Finally able to return the scaffolding, after months and months on rent....
Purchased some red cedar to build the front awning.
They were all rough sawn. Power and hand planed them down with a final pass with the sander.
Kipring
Kipring
29 Sep 2023 08:14 PM |
You know what goes next.
Kipring
29 Sep 2023 08:20 PM |
So, another learning tip for those reading. Go a full INCH bigger on your bucks for all openings. I went a half inch on some openings and that was not the best decision. Had to utilize a power planner and grinder to open up some of the openings for the windows.
While that was a pain - all of the openings were super flat for some reason.
Went with the Prosoco stuff on the windows. Glad I did. I've used the blue "goo" now and the red "goo". Red is better. I've also experimented with both the "paint grade" and tool grade Prosoco flashing. The tool grade is the way to go, the "paint grade" is more like smearing honey than painting.
Kipring
29 Sep 2023 08:26 PM |
Biggest thing I can say about the window install - if you can get your buck to go across the entire width of the ICF - do it. Much easier to install. I used mineral board for mine and they don't produce anything larger than 8.5".
Installation:
- seam sealer (fiber goo)
- Liquid flash
- Install of Window (used metal brackets - easier IMO)
- Latex Caulk on fins
- Liquid flash over top to finish up
Kipring
Kipring
Kipring
29 Sep 2023 08:35 PM |
Getting closer to framing inspection!
Garage Wall
Kipring
29 Sep 2023 08:36 PM |
Prepping for Front Door Entrance, final lift.
Kipring
Kipring
29 Sep 2023 08:42 PM |
Currently getting quotes on Spray Foam for the roof insulation. Until I settled on a contractor, working on final items for inspection, and sealing up the rafter sections with polyiso
Kipring
29 Sep 2023 08:47 PM |
Best part - took the wife to the site to show her for the THIRD time since starting the build.
First time I took her to the future home - she cried. We were standing in mud, in the middle of a big pit, as I had just finished the excavation.
Second time was after the first floor was just finished. I was thinking - this will really help her show that we are moving forward, all the work put in had a real purpose. Her response "Is this it??". Not exactly what I wanted to hear.
This time, she finally smiled. She could see light at the end of the tunnel and she was able to figure out her kitchen layout, finalize the size of the cabinets, and kitchen island. We can finally order the cabinets and start thinking about getting a plumber in while I work on supply and electrical. |
Kipring
27 Mar 2024 09:02 PM |
Insultation in the rafters/exterior wall
Installation of the first panel (sub)
Window Dressing for Front Porch
Kipring
27 Mar 2024 09:05 PM |
Flooring the Attic
Building Mounting Blocks for Exterior Fixtures and Penetrations
Installing Support for Large Wall Mounts
Kipring
27 Mar 2024 09:08 PM |
Spray Foam Done!
Last Min Adjustment - Walk in Shower Prep
More Mounting Blocks
