House with no Sheathing
Last Post 05 Aug 2022 09:47 PM by kenmce. 2 Replies.
Author Messages Not Resolved
JTD83User is Offline
14 Jan 2022 03:37 PM
Hi, I recently acquired a 70's home with wood clapboard siding. I had planned on taking off the clapboard, adding tyvek and re-siding. To my surprise, thee clapboard is functioning as the sheathing. I know the best is likely to replace clapboard with sheathing and start over but would now like to come up with an option of leave the clapboard and go over top. It is in Ok condition I am thinking I have a couple of options for new vinyl siding 1) Strap the entire house and applying new siding to furring strips. Would tyvek be used in this situation? 2) Apply 1" rigid foam over the clapboard and vinyl applied directly on the foam. Any advice for this situation? P.S. window and door detailing is not a major concern as they will be replaced. Thanks!
sailawayrbUser is Offline
14 Jan 2022 06:34 PM
Whatever you end up doing, make sure you have a water vapor drying path to either the inside or outside.
https://www.borstengineeringconstruction.com/Building_Assembly_Moisture_Analysis_Calculator.html
kenmceUser is Offline
When you put that layer of foam towards the outside of the wall you create a place where moisture can condense inside the wall.  You don't want water sitting around inside the wall.
People Online People Online: Visitors Visitors: 151 Members Members: 0 Total Total: 151
