Posted By smstrb on 10/19/2009 7:42 AM
Here's an
article that explains what to expect in terms of power output from the Honeywell.
Yep- ~67kwh/month, 800kwh/year at rooftop level, even in a fairly windy spot (have a steady 12mph?)- not exactly a great investment compared to, say, insulating all your hot water pipes or 1000 other modest efficiency upgrades:
You'd do about the same buying a clothes line and air-drying your clothes. (modest cost, requires lifestyle adjustment)
You'd double that with a drainwater heat recovery heat exchanger. (At 1/6 the upfront cost of the turbine, no user input required. Even the heavily subsidized turbine has a similar cost to unsubsidised DWHX, as well as ongoing maintenance.)
And if you don't experience a pretty stiff breeze
most of the time, fuggedaboudit- payback will be 3 months after never, even with large subsidy.
But if you want to show off your greenliness to the neighbors, it kinda makes a statement.
(To me that statement reads "I don't do arithmetic."
