I have never heard anyone suggest that before. It is a very interesting idea, but I would be a bit concerned that every window that has that "system" is now a fixed window and unless you pull the IG out, you won't be able to use the windows for ventilation.
Are you considering LowE coatings or gas infill in the IG units?
If not, then you will end up with a quad pane hybrid (part operating and part fixed), that won't have quite the same performance as a designed quad pane IG (and there aren't many of those around).
Adding LowE and gas fill to the IG will increase performance versus a non-LowE / non-gas infill window over using clear glass.
Four lites of clear glass will have a U-factor (US version) of about .25. This is a good number, especially when you don't want to change the windows for aesthetic reasons, but there are triple windows on the market that can reach .15 range or so, but they can be very expensive, adding an IG with LowE and gas might get you in that same range.
