Mounting to stucco
Last Post 22 Aug 2010 05:48 PM by cmkavala. 3 Replies.
bobarchitect39User is Offline
19 Aug 2010 09:08 PM
I'm thinking about mounting a bird feeder from the side of our house which is covered with an older stucco material.  Is there a good way to do this without damaging it's integrity?  What type of anchor should I use?  Thanks for the help!
21 Aug 2010 12:47 PM
Posted By bobarchitect39 on 19 Aug 2010 09:08 PM
is it stucco over block or frame?
22 Aug 2010 05:39 PM
It is just your normal frame construction. Thanks!
Posted By bobarchitect39 on 22 Aug 2010 05:39 PM
It would be best to locate a stud, then drill with masnory bit thru stucco until you hit wood, switch to a wood bit and drill a pilot hole for a small lag screw. Befoer mounting fill hole with sealant. after mounting add sealant to top of screw head.
People Online People Online: Visitors Visitors: 131 Members Members: 0 Total Total: 131
