vinyl vs fiberglass
Last Post 28 Feb 2011 11:11 AM by FBBP. 59 Replies.
Page 2 of 3 << < 123 > >>
Jhark312User is Offline
30 Nov 2010 06:18 PM
Posted By Lee Dodge on 30 Nov 2010 05:53 PM
Jhark312-
In your description of fiberglass, you state: "The resins are the binder, and the total composition depends on which resin was used as a binder. (Resin systems available include standard polyester ... "
From the Merriam-Webster on-line dictionary,
"Definition of POLYESTER
: any of a group of polymers that consist basically of repeated units of an ester and are used especially in making fibers or plastics…"
Therefore, you have verified my definition of fiberglass.
Perhaps you could also tell us the feedstock for polyester and the other resin systems, keeping in mind that you have already told us that "However, for many reasons, vinyl is a terrible choice:
a. it is a petroleum by-product."
Lee
30 Nov 2010 06:27 PM
Lee - I did state Polyester was one of the options, however, I also stated that EPOXY was used in the structural products I am speaking of.
by definition: There are two main categories of epoxy resins, namely the glycidyl epoxy, and non-glycidyl epoxy resins. The glycidyl epoxies are further classified as glycidyl-ether, glycidyl-ester and glycidyl-amine. The non-glycidyl epoxies are either aliphatic or cycloaliphatic epoxy resins. Glycidyl epoxies are prepared via a condensation reaction of appropriate dihydroxy compound, dibasic acid or a diamine and epichlorohydrin. While, non-glycidyl epoxies are formed by peroxidation of olefinic double bond.
Glycidyl-ether epoxies such as, diglycidyl ether of bisphenol-A (DGEBA) and novolac epoxy resins are most commonly used epoxies.
30 Nov 2010 06:36 PM
Chris - I respect your 40 years experience in the field, but you cannot honestly say that you have gone back to jobs 5 years, 10 years beyond the installation to "Check on the performance". Really? If "the website" was designed to malign the vinyl indistry, then verify the sources. they cant all be wrong simply because you have 40 years of experience to my 15 years. As to the matter of Off gassing: Read more about Master Bond’s Low Outgassing Adhesives at http://www.masterbond.com/produse/produse_lo.html Gentleman, while i apprecicate the debate, I think the science speaks otherwise. As I stated in my first post, the Discerning buyer should chose based on their own convictions, research, and budget. Its been a pleasure. JH NC, USA
30 Nov 2010 09:16 PM
Posted By Jhark312 on 30 Nov 2010 06:36 PM
JH;
I don't have access to all jobs, but I do some as long as 15 years, and trust me if a customer had window problems 10 years later they would let me know about it.
JH; vinyl-windows/blog . org , Really!  its halarious, they make it sound like a vinyl window support organization then proceeds to berate the product with "highlighted" statements along with a long list of window articles , some that have nothing to do with vinyl windows and have no link to even verify that the article s even exist.
Its a poor excuse for a blog site
30 Nov 2010 09:30 PM
01 Dec 2010 07:42 PM
Fibertec window SPECIFICATIONS:
GLAZING STOPS: uPVC exterior glass stop with co-extruded gasket, ensures a positive seal to the sealed unit glass.
01 Dec 2010 07:54 PM
Actually you make  GREAT point on this.  Any window company . . this particular company is really doing thier clients a disservice using a PVC glazing stop.  it will just curl up in the sun and cold temps.
Direct glazing is the best way to go, second only by an interior applied glazing stop.
Any window manufacutrer, and I mean ANY company that uses an exterior window stop made from a dimensionally unstable product or one subject to moisture retention (especially made from pvc or wood) is a danger!  RUN!  PVC or Wood extruded or milled at such small profiles simply cannot withstand the forces of nature and thermal expansion.
I can tell you from first hand experience that I have replaced MANY window that used this technique. its really a bad bad way to glaze.  besides, why put the glazing stop to the exterior where it takes the weather directly.  thats just one more place for a leak.
JH
01 Dec 2010 08:03 PM
Fibertec is a Fiberglass widow
I think you will find that most companies are using PVC glazing beads regardless of the sash composition
01 Dec 2010 08:06 PM
Not going to argue the finite details with you Chris.  I already told you I respect your opinion, I just simply disagree.
There is not benefit for me to trash the vinyl industry, I see it as a wasteful use of resouces that involves toxic substances that are unnecessary.  Wheter in manufacture or recycling, its consumes MASSIVE amounts of energy to produce, or recycle.  it seems counterintuitive.
To wit, should anyone want to confirm for themselves between the two material, I suggest they take a piece of vinyl and a piece of fiberglass and put them out in the elements, side by side.  these should be easy to come by from whichever window retailers you have locally.  I would be glad to do so myself, but I would be hailed as biased.  which I truly am.
I suspect my claims will be verified over a few months.
Thanks for the Debate Chris, and the not so pleasant, in my face, finger pointing, railing against my opinion(s) and facts.  This is supposed to be an open dialogue free form exchange of ideas, correct?  do they all need to agree with yours?
My sincere apologies if it seemed i was attacking you or your credibility personally.  Have a wonderful holiday season!
JH
NC, USA
01 Dec 2010 08:11 PM
JH;
thanks for being so humble
01 Dec 2010 08:25 PM
Marvin, I know doesn't use them.  Anymore that is . . thats one of their high points on the sell as I recall.  Apparenly they had issues with wood and vinyl (as did cardco and Jeld-wen) years ago (in the early 90's), and it led to many leaky doors and windows after the glazing compound or caulk at the glazing failed.
Some of the higher end $$$ companies are direct glazing with a pure silicone (dont get me started on VOC's) to take out that smaller stop as a weak point.  there is a distinct down side, and thats re-glazing of a broken sash.  But when it all shakes out, my preference would be buying a new sash over leaky windows.
Just my thoughts.
01 Dec 2010 09:21 PM
Posted By Jhark312 on 01 Dec 2010 08:25 PM
Just my thoughts.
Marvin Window does not say what their glazing beads are made of Standard Features:
Vinyl nailing fin (clad units)
Note: does not say what the glazing beads are made from in specs
Caradco windows:
Can’t find specs but this popped up right away:
http://www.bobvila.com/wwwboard/messages/rotting_caradco_windows_79080.html
seems like it does not matter what the glazing beads are, the wood rots in ten years according to the Bob Villa article
JenWeld………. Makes all types windows and offers a materials comparison (but no fiberglass?)
Aluminum – A lightweight and strong material that is a cost effective alternative to wood.  This material is corrosion-resistant and performs well in most climates.
Vinyl – A strong plastic material that is used for its durability, energy efficiency and ability to stand up to the elements.  This material will never fade in color, flake, peel or rot.
Wood – Wood comes from trees that grow in a variety of species, such as fir, pine, mahogany or alder.  Each species has a range of characteristics, like grain, color and sap content, which contributes to its unique appearance.
Clad-Wood - Like a coat of armor, cladding is a strong layer of metal on wood, providing extra protection and low maintenance benefits with no exterior painting required.
I am not talking about "reglazing" I am talking about the original PVC glazing beads, direct glazing? please explaing that further I understand the silicoln sealant, but whats holding the glass in ?
02 Dec 2010 08:39 AM
There is no glazing bead.  there is clear silicone between the exterior cladding and the glass.  The glass is held in between the exterior cladding and the interior wood sash.  No Glazing bead.
2.4 GLAZING A. Select quality complying with ASTM C 1036. Insulating glass SIGMA/IGCC certified to performance level CBA when tested in accordance with ASTM E 2190. B. Glazing method: Insulating glass (altitude adjusted). 3 C. Glass Type: Clear, Bronze, Gray, Reflective Bronze, LoĒ2 272® with Argon, LoĒ3 366® with Argon, Tri-pane LoĒ 179™with Argon, Tri-pane LoĒ 2 272® with Argon, Tri-pane LoĒ2 272® with Krypton/Argon, Tri-pane LoĒ 179™ with Krypton/Argon, Tempered, Obscure, Laminated. D. Glazing seal: Silicone bedding at interior and exterior.
Same with the fiberglass windows.
Surely, Are you really going to quote a manufacturers website about how great vinyl is?? You dont think they are biased?  Just the same as the vinyl industry websites are pro vinyl?
I would consider the USGBC as a solid source for information becuase they dont have an axe to grind, no stake in its success or failure, and it is a LARGE (thousands) group of people from which consensus has to be reached.   Ergo, there is no intentional bias.
02 Dec 2010 09:00 AM
JH;
Windows 101: the glazing sealant is not the  same as the bead, it is what holds the glass in the sash, thare has to be a way to replace a broken piece of glass and that would be by removing the glazing bead.
your specification listed does not match your statement
the vinyl statement is from JenWeld that makes wood, aluminum and vinyl
windowrookieUser is Offline
02 Dec 2010 12:19 PM
PS: redo your homework……………………. fiberglass resins continue to “off gas” for months, The toxic element in fiberglass is polyester resin. Polyester resin has a styrene carrier which outgasses VOCs.
Chris
I believe that you are the one who needs the homework. As fiberglass is an inert product a Thermoset material as opposed to a Thermoplastic like PVC, the only off gassing is in the manufacturing stage. Once fully cured there is no off gassing unlike PVC. As you mentioned you have vast experience with wood, aluminum and vinyl but did not mention fiberglass. I must then ask you how are you credible in anyway to discuss this as you mentioned you do not have ANY experience in fiberglass. How can you mention that vinyl is the least problematic if you clearly stated that you have never used fiberglass???
Please read this link and I want your 40 years of experience to comment on this.
http://www.sabmagazine.com/blog/2009/03/12/the-environmental-legacy-of-plastic-buildings/
Thank you.
02 Dec 2010 12:21 PM
Chris -  Windows 101?  Really? LOL
Try "READING 101" -
1.) I stated there was "a down side, and reglazing is a problem", however, it is relatively leakproof. (Embeded in silicone).  No need to re-glaze if its broken, you get a new sash.
2.) the Jeld-Wen statement - again, your going to take the word of a manufacturer that profits from the SALES of VINYL?  Sure, they would be honest if it werent a bad product.  they lost 300 million dollars last year, I dont think they are going to speak ill against a profitable side of their own business.  No more than McDonalds is going to tell you that Hamburges and fries make you fat! . . .  get real.
As to the Bob Vila Article, thats funny you mention that, because they use roll formed (Cheap) cladding at the sash, and it LEAKS!  oh, and they are a divison of Jeld-Wen's window brands.
Do you suffer from some dillusion that you are the omnipotent expert advisor on all things building?  And do your replies need be so condescending & dimunitive?  Do You have to make dissented opinions this personal???
Your Arrogance is ASTOUNDING! Maybe after 40+ years in the business its time to retire if you cannot embrace new ideas or technologies.
After searching and a phone call to my local retailers, I am uploading 2 cut sheets found right on thier fiberglass window websites (integritywindows.com & PellaWindows.com)
Do tell us professor know it all "Windows 101" . . where in the attached picture is the glazing Bead???  I have even circled the glass/sash area so you can find it quickly.
There is none.  But somehow I feel certian you won't gracefully admit that your wrong, or that you might have learned something, but will move on to do what??? . . . another snied comment? trash this window because its not in your accepted practices box?  or because it has a vinly nailing fin? Lets see what bloviation comes next. . . . .
I won't let you goad me into further arguement or disagreement.  You seem to lack the gentility to conduct a reasonable debate in which someone disagrees with your opinions.   Good Day!
Attachment: Fiberglass_Window_Sash.pdf
Attachment: Pella_Fiberglass_Casement.pdf
BRINDASBABYUser is Offline
02 Dec 2010 12:57 PM
From what i see in those pictures the glass can be removed and replaced which therefor means that the glass does not have a actual glazing bead. I know on the old Peachtree series Ariel Casement units the interior of the sash was a vinyl material and would pop off revealing the glass which then could be removed and a new glass put in.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Hot Springs Village, AR 71909
Office: 1-501-984-6074
Fax: 1-501-984-6073
Email: [email protected]
02 Dec 2010 01:10 PM
This Old House Press Release “Worrisome Windows”, “Vinyl softens at 165˚, A Temperature easily achievable in the space between drapes and the windows on a sunny day. Vinyl expands and contracts 7 times more than glass. This action can pop seals between frames and glass. Vinyl is simply not suitable on its own as a window material. Says Mike Compleu of Anderson Window Corp who has never made an all vinyl window.
This is on the vinyl-windows.org website. Not entirely true because Andersen owns Silver-Line who is a vinyl window manufacturer. and if a article is written they should make sure and get the companies name spelled right as well.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Fax: 1-501-984-6073
02 Dec 2010 01:24 PM
Also the majority of the articles i see on that sight are from the mid 90's when vinyl windows first came on the market. The vinyl manufacturers since that time have come a long way in developing their products to last longer and be more stable. Used to you wouldn't see anything but white vinyl windows. Now you see darker colors available in vinyl due to the technology enhancements since vinyl first arrived on the scene. If this was the case vinyl siding wouldn't be used, composite decking that had pvc in it wouldn't be used.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Fax: 1-501-984-6073
02 Dec 2010 01:29 PM
Thanks for that info Windowrookie.
Interesting article.  I honestly didnt know that the medical profession was also trying to chase PVC from their field .  Its a story I tell when I can.  Truth is, Plastics and PVC are never going to be entirely phased out.  But if GBT is about a movement toward making a difference, then every decision to avoid dangerous products is a decision to steer manufacturing from it for lack of demand.
There is a difference between PVC and the plastics that are used in many other forms (PVC, ABS, PET, Etc)   They cannot all be avoided and we start packageing our lunches in corn husks.  But we can chose NOT TO PARTICIPATE and do so very vocally if we want to turn the tide from some of the more toxic and enviornmetally unfriendly products.
I am NOT an earth worshipping tree hugger, though I say KUDOS to those that are, but I do believe I would like to make a difference and conserve for those that come after me, rather than consume all I can for whatever directly benefits ME ME ME in the right here, right now.
People Online People Online: Visitors Visitors: 175 Members Members: 0 Total Total: 175
