Most of the older mobile homes and RV’s around usually have metal roofs, most often aluminum. In order to keep this type of roof in good condition, again it is usually only required that you inspect it regularly and keep it clean. For most metal roofs, it’s okay to clean it twice a year using an automotive wash and wax cleaner. You may notice that many older RV’s with metal roofs have unsightly black marks or streaks running down the sides. This is caused by dirt that runs off the roof when it gets wet. If you clean your roof often, and especially if for whatever reason it gets particularly dirty, you’ll be doing yourself a huge favor with regard to getting rid of these dirty black streaks.
It might be advisable to clean your RV roof more than twice a year if you are often parked underneath trees or other places where a lot of debris falls onto your roof. Debris such as this can cause unsightly and permanent stains if it is left too long. |
