New air sealing technologies
Last Post 07 Dec 2018 12:45 AM by Dilettante. 5 Replies.
thoner7User is Offline
04 Dec 2018 07:56 PM
I saw on TV last night a new technology for air sealing. The put your house under positive pressure, and then they must put some particals into the air that then plug up the openings where drafts occurr. I wish I knew more about it but is anyone familiar with this product? It would be great for my current home
04 Dec 2018 09:14 PM
AeroBarrier (tm) essentially the same technology & goop as the Aeroseal (tm) duct sealing system:
https://www.greenbuildingadvisor.com/article/aeroseal-rolls-out-air-sealing-technology-for-houses
https://www.greenbuildingadvisor.com/app/uploads/sites/default/files/California-Builder-Report.pdf
It's probably NOT something you would want to do for an already-finished house, but may make sense in new construction as soon as the shell is complete.
05 Dec 2018 03:23 PM
Wow thanks. I'm going to look into this, although it's so new I doubt it's available in my area. I haven't had a blower door test done but I know it's bad!
DilettanteUser is Offline
05 Dec 2018 04:26 PM
Posted By thoner7 on 05 Dec 2018 03:23 PM
https://aeroseal.com/residential/find-a-dealer/
They've been doing duct sealing for ages.
This is just a modification of that tech.
And the face-slapping part about it is that it's such a simple idea.
You do your regular air-sealing and get all the really gross openings closed up.
Then, instead of going anal on your detail work, you use this to close up pretty much everything under a half inch.
05 Dec 2018 06:54 PM
I you do this in an already finished house you're going to have a tacky film of gluey-stuff on all sorts of surfaces, some of which might not be readily cleanable. This is really for new construction, PRIOR to painting/finishing out the interior.
Exactly. If you're gutting a place, or doing new construction, you should be good.
Now, it MIGHT be possible to do individual rooms this way (this is how they obtain coverage). But you'd wanna talk with your contractor for that.
People Online People Online: Visitors Visitors: 208 Members Members: 0 Total Total: 208
