cmkavala
cmkavala
JeffD
| 05 Jan 2011 03:45 PM |
Chris, Real nice project! Why are there so many purlins on the roof? I guess they need places to hang the building systems from? The walls look right with a top girt and intermediate girt. |
| Metal SIP Building Designer<br>jeff@panelfusion(dot com) See us on Facebook |
cmkavala
| 05 Jan 2011 05:41 PM |
Posted By JeffD on 05 Jan 2011 03:45 PM Chris,
Real nice project!
Why are there so many purlins on the roof? I guess they need places to hang the building systems from? The walls look right with a top girt and intermediate girt. only 4 purlins were needed to carry the 37 ft. roof panels , the others are to carry 8 HVAC Air Handlers and an additional 15# PSF load for audio and lighting equipment over the stage. |
Alton
| 05 Jan 2011 07:58 PM |
Thanks for explaining the extra purlins. Sometimes we have more load than just supporting a roof. |
cmkavala
| 05 Jan 2011 08:34 PM |
Alton;
bays are 35' oc and purlins are W14x22 @ 8' oc |
cmkavala
| 11 Jan 2011 04:18 PM |
Hip beam 20 feet long supporting panels  rediron frame supporting 70 foot span over sanctuary  |
Jelly
| 14 Jan 2011 08:19 AM |
Chris, at that smaller gable roof at the front, is that red iron member screwed directly to the SIP panels? |
cmkavala
| 16 Jan 2011 07:29 PM |
Jelly;
no there are 2 clips thru the panels that support the gable beam |
siddle
| 18 Jan 2011 01:08 AM |
Hey Chris! I thought I'll share something about us and I believe it may be useful and informative to others as well. Metal building kits / garage building kits from Absolute Steel come in a variety of styles and models to fit most any budget and taste. Our metal building kits are designed for light use residential or heavy use commercial. We’ve got the traditional looking metal building kits garage building kits for a small 200 square foot garage, or a large 4,000 square foot commercial metal building. Only Absolute Steel offers you a metal building kit that is constructed with a galvanized frame system that goes together easy. Our garage building kits are designed to be assembled with no special, high priced rental equipment such as forklifts and cranes. ____________________________________________________________________
Absolute Steel—Steel building kits easily assembled by unskilled labor using common tools. Watch the video & see for yourself.
cmkavala
| 19 Jan 2011 12:34 PM |
Updated............. new employess learning the system  You can see the shear volume of the interior space 32 feet tall at the peak  Toppng off the tower  |
crockervf
| 25 Jan 2011 02:07 AM |
Chris - What will the exterior and interior finishes be? Do these sips require exterior cladding? How about the roof, is it water tight? If not, what roofing system is planned? This looks like a very clean building system. Thanks for posting this. |
cmkavala
| 25 Jan 2011 02:57 AM |
crockervf;
This particular job will have stucco on exterior walls , standing seam steel roof and interior drywall finish. This job is too cut up to do with no cladding.
simple roofs (no valleys) can be simply taped at joints for a waterproof roof
Green1
| 26 Jan 2011 10:32 PM |
Chris , Nice looking job, Well done Ralph Locke CGP www..Flgreenbuilding.com 386-490-4599 |
Ralph Locke, Deland,Fl www.Flgreenbuilder.com 386-490-4599 |
cmkavala
cmkavala
Jelly
| 07 Feb 2011 07:41 AM |
Chris, how are those awnings put together? Is that triangle shape supporting the sides a piece of SIP panel? |
cmkavala
| 07 Feb 2011 08:00 AM |
Amazing isn't it |
Jelly
| 07 Feb 2011 08:44 PM |
like magic  |
JeffD
| 09 Feb 2011 04:06 PM |
The panel cut outs from windows and doors are great for small canopies and eyebrows over windows.
