The local orange box store is now carrying the 10.5 W Cree CR6 (R30 replacement) for ~$30 (well under internet pricing from numerous vendors), so it seemed worth risking $60 for a pair of sockets where dimmable edison-base CFLs weren't delivering acceptable performance on the low-luminosity-end.
Right out of the box:
The color temp of the two units differed noticeably, but not enough to bring me back to the store.
On the original 1980s vintage Lutron dimmer they flickered horribly at the bright end of the range, but at half luminosity and lower they were fine. Replacing the antique dimmer with a more recent low-end Lutron (model
TG-600PR) it's still possible to find a few narrow settings where the CR6s will flicker, but for most of the range they dim acceptably & stably (but not as smooth & nice as a pin-base CFL in a dimmable fixture).
At
very low luminosity it's possible to see blue & red fringing on the LED through the diffuser, but it's not objectionable. The color temp difference between the pair is more noticeable at the very low end of the range, but still not too objectionable.
The heat-sinking & ventilation design is dramatically less than the (more expensive) Cree LR6 but the max-luminosity is a bit less too (575 lumens as opposed to 650 lumnens on the LR6), but they're otherwise quite similar, with comparable ~55 lumens per watt efficiency (better than most cold cathode bulbs, but lower than pin-base CFLs in ballasted fixtures.)
Visual efficacy is
quite good, with good color rendering (better than all but the very best CFLs) and low glare. In non high-ceiling applications where you don't need the high-end lumens they're decent- better than many "cone of light" high-glare lower CRI R30/PAR38 LED units out there and anywhere near that price point.
The CR6 fills the bill for my intended use, and since they'll be run mostly at 1/2 to 2/3 power they should outlive their 35000 rated hours even without the bigger heat sink of it's LR6 sister. At the $30 price point it's a decent value, but I'll wait for the
L-prize PAR38 entries to show up before swapping out the edison-base CFLs from other R30 sockets, which will have 2x the efficiency and 2x the high-end luminosity.
