Building on slab in south Florida
Last Post 17 Apr 2009 11:30 AM by Polycore. 5 Replies.
rlsmith017User is Offline
22 Mar 2009 09:31 AM
   Everything I've read about green building talks about the importance of insulating a slab when building.  Is this the case in south Florida, where the ground temps run 70 to 72 degrees?  I'm wondering if you aren't better off without insulation, since the slab temperature would moderate the outside climate year-round. - cool in the summer and warm in the cool spells.
   Am I wrong?
Roger
Roger
22 Mar 2009 10:27 AM
Posted By rlsmith017 on 03/22/2009 9:31 AM
   Am I wrong?
Roger
Roger;
You are right, the benefit of slab insulation in Florida is minimal
buck3647User is Offline
22 Mar 2009 10:31 AM
More of an issue in Florida is the humidity. When a structure is built without air leaks the interior becomes vulnerable to humidity.
22 Mar 2009 10:40 AM
Posted By buck3647 on 03/22/2009 10:31 AM
buck3647;
That is true, When you build a tight building in Florida it is imperative that the HVAC system is not oversized. In a old conventional building it was common practice to upsize by another ton of AC just cause it was cheap insurance.
In a tight building envelope, the HVAC system MUST be properly sized so it will run long enough to get the humidity out, it is also necessary to bring in controlled fresh air.
SummersUser is Offline
13 Apr 2009 07:41 AM
Roger, Comments regarding insulation are correct and applicable in several areas of the US and not just Florida! More important than insulation is a Vapor barrier for your slab.
Consider proper sizing of the HVAC system that has been mentioned! This is a REAL problem, and unfortunately not understood by some owners/ builders! An unscroupoluos AC contractor will up sell to a larger ton unit [he makes more money] without telling of the temperature - humidity relationship. If you walk into a cool/cold house in the morning and notice you have condensation on the inside of the windows. You've been oversold!!
Back to the question: A vapor barrier under the slab is subject to tears, penetrations and being compromised during construction. This allows moisture to wick through a slab and seek the low humidity interior of a house. Especially important in high water table environments or where rain accumulates after a hard rain. When the AC does it's job and removes interior humidity, Moisture in the slab is drawn into the occupied space.
Most common are flooring issues where this moisture collects on a slab top surface and Under a Floor Covering. This moisture causes mastics/glues and adhesives to loose their bond. In some cases bubbles are observed under a coating or a bubble will appear where sheet goods have delaminated from a floor and are raised above floor grade. A razor knife to to open one of these areas will reveal a floor covering that is disbonded from the substrate and may actually have ponded water under the covering.
Tons of information out there about MVER and the deletrious affects! Suffice to say -- pay attention to protecting your slab from Moisture Vapor Transfer, or you'll pay for it many times over after you are COed.
The Cost Effective Answer to Concrete Corrosion
PolycoreUser is Offline
Roger,
      You are right, you don't have to worry about insulating you concrete slab, due to your location. The ground won't be subject to frost heaving, in the cool months. I am sure you are well aware, but I think it is important to note that good insulation for your walls and roof are still very important, even in Florida. Insulation will do two things, firstly it will keep the cold out in cool climates, and it will keep the cool inside in warm climates. If you live in Florida and run AC 10 months of the year, your insulation is just as important as someone that heats their home 10 months of the year. Just something to keep in mind.
Cheers.
Polycore Canada Inc.<br>www.polycorecanada.com<br>1-877-765-9267
People Online People Online: Visitors Visitors: 155 Members Members: 0 Total Total: 155
