Posted By ICFHybrid on 18 Jan 2014 07:42 PM
The install manual for each model should be quite detailed about the distances and height limits for mounting the units apart from each other, but going between floors is not a problem.
ETA: Document the locations of the linesets very carefully, using photos and reference points. Future subs are not accustomed to finding such things in the walls.
I plan on burying the lines within the exterior wall by taking out the ICF EPS foam and then foaming over them and stucco. My other question is how wide are the exterior lines? Can one place them beneath the 2.5" of EPS foam in the ICF, foam it over, then stucco?
The exposed retrofit lines I sometimes see (white vinyl) is not aesthetically appealing. It can get gaudy looking.
