VRF Outdoor Unit utilizing typical air handler plus Zoning.
Last Post 10 Jul 2015 08:52 PM by ricky_005. 0 Replies.
ricky_005User is Offline
<!--[if gte mso 9]> Have a floor plan, which I have laid out four zones using two high static pressure variable speed air handlers. One 18,000 btu unit is dedicated to the main living space; the second air handler covers three zones using motorized dampers for the Master BR, Guest BR and Media RM. I have not calculated loads yet, but for the time being I am assuming 18,000 btu unit for each air handler.
The outdoor unit will be a mult head VRF system from Mitsubishi, Daikin or some other manufacture.
  • Here is the link to Mitsubishi air handlers
http://www.mitsubishipro.com/en/pro...vz-series-
  • Here is the link to Daikin air handlers
http://daikincomfort.com/residentia...-and-coils
I still have not looked into the damper zoning system yet as nether listed above like to market them.
The idea is to only have two high static pressure air handler for four zones to possibly reduce long term AH maintains cost.
[script removed]
<!--[if gte mso 9]> Normal 0 false false false EN-US X-NONE X-NONE
People Online People Online: Visitors Visitors: 591 Members Members: 1 Total Total: 592
