Green/Energy-Efficient Design and Planning
HVAC Zone Controller
Last Post 27 Mar 2016 09:13 PM by
berky
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
berky
26 Mar 2016 11:38 PM
Hi everyone,
I recently had my HVAC designed and I have a few questions regarding how to set up a multi-zone controller with a single HVAC unit.
My design came back with 3 zones (1 per floor, including basement). I was planning to use an EcoBee3 for the thermostat, but I'm trying to figure out how that would tie into a zone controller and how the zone controller actually works.
Which piece communicates with the furnace? Do I need more than 1 thermostat since the ecobee3 can have multiple remote sensors? What dampers and controller do you recommend?
27 Mar 2016 11:04 AM
I'd provide significant bypass for each damper - so there is sufficient flow for the furnace even when only the smallest zone is calling for heat. Ie, think of zoning as providing a fairly small adjustment to the amount of heat being delivered, not an on/off control.
Without looking, my guess is that you need 3 of the thermostats for 3 zones. The furnace needs an on signal when any of the zones are calling for heat.
berky
27 Mar 2016 11:32 AM
Thanks for the response. My understanding is that bypass ducts should not be used. I'm basing that solely on http://www.energyvanguard.com/blog-building-science-HERS-BPI/bid/44187/Navigating-the-Twilight-Zone-The-Hidden-Flaw-in-a-Zoned-Duct-System
even still, do the returns get dampers too? I assumed they would always be open.
I assumed that the zone controller would be the interface to the HVAC. Is that not the case? I guess that's part of my non-understanding is how each component relates to the others and which pieces provide each signal.
27 Mar 2016 08:49 PM
They are talking about a bypass from the supply to the return, not a stop on the zone damper that allows air to flow through it even when it is "closed". Pulling from a return duct while a supply duct is off (or even restricted) in a closed door room will depressurize it - causing high infiltration.
berky
I gotcha. Sorry I misunderstood what you meant originally. Do you know of a brand of dampers and controller that has these features?
Btw, in all my searches all I can find is a Honeywell and Zonefirst system. Are these the most common? Are there other 'good' ones out there?
Membership:
croccohvacusa
People Online:
