Posted By sgo70 on 08/03/2009 7:21 PM
I guess with nothing to stop the piston except the foam it tries to fire it right out and breaks the stop.
Maybe so, but I have a hard believing that's the case. Were the guns sized for that long a nail? If not the piston could be bottoming out before the nail stops in the concrete. You sure you used a low enough power shot? In usage such as pinning 2 x 4s to concrete the wood isn't going to offer much resistance. The way I see it has to be the concrete that provides the stopping resistance. Did you push the nail through the foam and bottom it out on the concrete before firing? If not maybe that's where the difference with wood is, the nail just flies through the foam and abruptly stops when it hits the concrete. With wood there's some resistance to its travel as soon as it leaves the gun.
I suggest you try a nail without the washer but put it through a fender washer. Push it through the foam until it rests on the concrete, then fire the gun. I think that would work. With as many fasteners as you need to put in it's worth another try, IMO!!!
