INTERIOR cross-strapping and blown cellulose?
Last Post 22 Dec 2009 02:25 PM by Dana1. 9 Replies.
John7User is Offline
19 Dec 2009 08:47 PM
Has anyone seen or done cross-strapping on the interior of a normal stud wall? I am thinking of standard 2x4 walls with 2x2 horizontal cross-strapping on the interior, then stabilized/wet binder blown cellulose insulation. Not trying for super insulated wall as I am in Vancouver (5700 HDD) but am looking for an insulation system that is simple (ie inexpensive) for the insulation contractor (I'll do the cross strapping etc.). I need to avoid exterior XPS or other exterior "vapor barrier" forming foam boards. Our climate doesn't agree with them. I am looking for R values, photos, personal experiences and details. Thanks John
smartwallUser is Offline
20 Dec 2009 07:54 AM
The cross stapping will make it difficult to install the wet spray. You could have the cellulose or fiberglass blown behind a fabric stappled to the studs.
20 Dec 2009 03:23 PM
I have no experience with wet cellulose installation. Would horizontal 2x2 on 24" centers cause problems? I am assuming you mean voids behind each piece or other difficulties in building up the fill. (Not interested in regular dry cellulose because settlement would likely negate any increase R value in cross strapping/thermal bridging). Alternatively could I have it sprayed at the standard 2x4 stage, then cross-strap and have them come back? I realize there would be extra costs but is it possible to build a second layer of wet cellulose without blowing out the first one? Thanks John
Jesse ThompsonUser is Offline
20 Dec 2009 06:50 PM
A friend of our likes to build this way, has done a series of houses with 2x6 ballon framing, cross strapped 2x to the interior. Like smartwall said, dry, netted dense-pack cellulose works well for this method.
Here's a link to one of Chris' projects built in this fashion: Harmony House
Jesse Thompson<br>Kaplan Thompson Architects<br>http://www.kaplanthompson.com/<br>Portland, ME<br><br>Beautiful, Sustainable, Attainable
20 Dec 2009 06:53 PM
Oh, and settlement isn't an issue with dense-packed cellulose (3.5 lb / cu ft+). At that density the fibers interlock and it can't settle any more, it really is drum tight against the netting.
21 Dec 2009 09:31 AM
AKA "Mooney Wall", cross-strapped can be easily done blown-in-bag using mesh (wet or dry, dense-packed or not. Wet-sprayed & dense-packed is usually well worth it for the long term perferformance though.)
http://www.builditsolar.com/Projects/Conservation/MooneyWall/MooneyWall.htm
http://www.builditsolar.com/Projects/Conservation/MooneyWall/M02.pnghttp://www.builditsolar.com/Projects/Conservation/MooneyWall/a5_seq.JPG
http://www.builditsolar.com/Projects/Conservation/MooneyWall/MoreMooney.htm
http://www.builditsolar.com/Projects/Conservation/MooneyWall/MoreMo4.jpg
21 Dec 2009 11:30 PM
Mooney Wall - love it!
Awesome to have such detailed information too.
Is there some special sealing around the electrical boxes? I am wondering if the mesh bulges or blows out around them.
John
22 Dec 2009 07:26 AM
We use rubber bands
arkie6User is Offline
22 Dec 2009 10:42 AM
The Mooney Wall looks like a neat idea. I wonder if it could be improved on just a bit by adding 1/2" XPS or Polyiso on the interior side. This would bring the wall thickness out to a standard 2x6 framed wall thickness of 5.5" (3.5" stud + 1.5" 2x strapping + 0.5" foam = 5.5"). This would make installation of standard exterior door casings for 2x6 walls fit better, plus it adds another thermal break and 2.5 to 3.0 of R value to the wall insulation. This could be done on the outside as well if using fiber faced Polyiso.
Posted By arkie6 on 12/22/2009 10:42 AM
Great minds think alike!
All thermal breaks are good. The Mooney Wall approach reduces the unbroken thermal bridging to the intersections where they overlap.  But just 1/2" strips between the 2x4 and the cross-members would be as effective as full sheets on the interior (!).
I'd think this is an application where double-layered pads/short-strips of 1/4" Thermablok aerogel may be be more cost-effective than full sheets of XPS or similar:
http://www.thermablok.com/pictures/studley-1.jpg
http://www.thermablok.com/pdf/Thermablok_Product_Information_20090601.pdf
But full stud-length strips of 1/2" XPS would have reasonable compression characteristics to handle the lateral members, would easy to field-fabricate, and wouldn't interfere with blowing insulation.  Low density iso would be too squishy to use between the framing in the same way- you'd need to find a source for 2lb density iso sheets in 1/2" thickness (and I'm not sure it exists.)  1/2" of aerogel would have an R value of ~4+, compared to R2.5 for XPS.  The thermal break on the rest of the stud with  2" (of framing + XPS/aerogel framing spacers) of cellulose offered is about R6-R7, so aerogel spacers would even that out considerably.
People Online People Online: Visitors Visitors: 220 Members Members: 0 Total Total: 220
