Desiccant cooling
Last Post 06 Jan 2010 09:28 PM by slenzen. 4 Replies.
05 Jan 2010 09:10 PM
http://www.solarteam.org/page.php?id=641
Are there some sound DIY applications for this in residential?
liquid desiccant waterfall
<!--aA39vnkdl2409bnofaep08rhg34kjGser98gZZZ34g-->
Liquid Desiccant Waterfall Close Up
Until the mid twentieth century, a house cooling system meant ... a fan, and before that, a window. The key difference between a simple fan and an air conditioner is dehumidification -- an important distinction, because, as the saying goes, "it's not the heat, it's the humidity" that makes Washington, D.C., area residents uncomfortable in the summer.
The problem with air conditioners is that they are energy hogs.  A conventional air conditioner uses a pump to compress and expand a refrigerant, supercooling the air and causing the water vapor in the air (the humidity) to condense (become liquid).  It dumps the collected water outside. This takes a lot of energy and generally it can only be done with electricity.  Electricity is generally a lot more expensive to create than heat, for example, making conventional AC cost more too.
The LEAFHouse team is exploring a technology relatively new to single-family home design called a Desiccant System. This concept has been proven sound on larger buildings.  The basic idea is to use a material called a desiccant (in our case a type of salt called calcium chloride) to absorb water directly from the air without all the complicated machinery and energy requirements of conventional AC.  As the desiccant absorbs water, it becomes diluted and its ability to dry the air declines. The desiccant needs to be regenerated.  This can be done by simply heating up the desiccant and letting the water evaporate to the outside air.  Thus, the desiccant is concentrated and ready to return to its job of drying the indoor air. LEAFHouse uses heat from the Solar Hot Water collectors to regenerate the desiccant.  Remember that heat is a lot easier and cheaper to make than electricity, so this is a BIG improvement over conventional AC for dehumidification.
Most commercial systems use a solid desiccant. LEAFHouse has taken the innovation of desiccant systems a step further by using a LIQUID desiccant.  We believe this will make the system safer, easier to maintain, and cheaper too.
True to our philosophy of integrating technical and aesthetic goals, we have chosen not to hide the Liquid Desiccant Waterfall (LDW) system, but to make it a beautiful and functional indoor 'water feature'. Likewise, the regenerator is a prominent techno-sculptural element that will greet visitors on the Mall as they approach the front door to the house.
In summary, the dramatic Liquid Desiccant Waterfall removes humidity with very little energy, greatly reducing the job of the air-conditioner (used only for cooling). Calcium chloride, a highly absorptive salt, is mixed into the waterfall, where it captures moisture out of the air. Heat from the solar hot water collectors is used to regenerate the desiccant.
 Ever consider a waterfall in the living room? I thought not. But there are very good reasons to  consider one. If you live in a hot and muggy climate and want to build a new house that is naturally comfortable  and energy efficient, this is one simple and carbon neutral way to do it.
Normally, flowing water does not take moisture out of the air. But add just one ingredient to your indoor waterfall and, presto; cool dry air is made from hot and muggy air.
The ingredient?
The secret ingredient is calcium chloride added to the water. Calcium chloride, a salt, is a desiccant, just like table salt and the grain of rice that you put in the shaker to keep it flowing freely. It is hygroscopic, meaning it attracts water molecules from the air by absorption or adsorption.
This liquid desiccant system is a wet flowing feature that can suck the moisture out of your indoor air using almost no energy. The water wall idea was first used by University of Maryland students to turn a functional mechanism into an aesthetic feature in their LEAF House in the DOE Solar Decathlon. To recycle the desiccant, the water is evaporated, re-concentrating the salts to pull more moisture from the air in its next cycle. To keep energy costs low, they used solar hot water heaters for the evaporation cycle. Then once the desiccant is concentrated again, it is ready to do more work pulling water out of the air.
These systems have been used in the commercial and manufacturing sector for many years. Complex piping in commercial buildings (running on carbon heavy fossil fuels) also use desiccant systems to remove mold growth and other consequences of moist air.
Desiccant use in commercial A/C systems is not a lovely thing. A waterfall is. And it is a very planet friendly low carbon cooling system.
BruceUser is Offline
06 Jan 2010 08:15 AM
That sounds pretty cool.   Pun intended.
What makes the desiccant pull moisture from the air if it is in water?  It would seem the desiccant would be saturated totally by the water it is in and never get around to taking any from the air.
Bruce
06 Jan 2010 12:36 PM
Posted By tb1472000 on 01/06/2010 8:15 AM
Bruce
At a high level of CaCl concentration in the water it becomes a buffer for the room air's humidity- the vapor pressure of the solution is neutral compared to that of the air, and there is no evaporation of the water to the air.  If the RH of the air rises, the solution takes on water from the air. If the RH of the air falls the difference changes sign, and it releases water vapor to the air. But the magnitude of these differences is always small so it takes both time and a maximal surface area to move much humidity.
Heating the concentrated solution in the regenerator raises it's vapor pressure so water vapor is released there, then as it cools back to room temp it's vapor pressure falls relative to the room air, to be able to absorb vapor at the surface once it's exposed to room air on the waterfall.  There's a lot going on in the regenerator behind the waterfall that they're not tellin' ya details on (due to patent protection issues, I'd suppose.
But the waterfall itself is easier to understand. In a waterfall the surface area to volume is very high, which makes the vapor transfer work fairly quickly, and the water/CaCl solution is constantly being mixed, but I'd think it still has to be quite a bit of surface area to dry out your house.
Still for the right price I'd be willing to try it out- the cooling load at my house is nearly ALL latent load, and mechanical dehumidification is a measurable fraction of my annual power bill.  (I don't need it to look pretty either, eh? I'd stuff it in the basement if I had to.)  It's the sort of thing that will take up quite hunk of wall space and it may be hard to situate it in a lot of residences.
06 Jan 2010 02:01 PM
Dana,
I appreciate the clear and detailed response.
I'm not sure what you do for a living.  However, you are a great teacher as I've seen you've taught many others before that have come here seeking knowledge.  There are many here that are glad you are giving back in such an unselfish way.
Bruce
I'd love to have a large water feature wall. Put the CaCl in the system during summer for dehumidifying and remove it in winter for some humidification.
People Online People Online: Visitors Visitors: 98 Members Members: 0 Total Total: 98
