Adhesive For Treated Lumber
Last Post 29 Sep 2010 08:58 PM by Stonelake. 7 Replies.
StonelakeUser is Offline
23 Sep 2010 05:32 PM
We will be fastening 1 X 3 treated furring boards to OSB sips panels.  In addition to using screws we want to bond with adhesive.  Anyone know of a product that will work well with both treated lumber ,  and OSB  ?
Bob IUser is Offline
23 Sep 2010 06:12 PM
Is a wall or a roof? Siding over it? Curious why you are using treated lumber?
23 Sep 2010 07:30 PM
Posted By Stonelake on 23 Sep 2010 05:32 PM
PL400 works with both, but as Bob said wall or roof. If roof where is underlayment going to go or if it is a wall where is rainscreen going to go?
29 Sep 2010 06:26 AM
This is a wall. We are using a mortarless brick ( Novabrik) and the architect specs call for treated 1X3 trreated furring strips,  glues and screwed, with felt or tyvek over furring.  My carpenter says that putting the wrap over the furring strips will be a bitch  especially if we use IWB, and recommends more screws rather than  glue, so that we can put the wrap on before the furring strips.
29 Sep 2010 06:49 AM
Posted By Stonelake on 29 Sep 2010 06:26 AM
your carpenter is correct
29 Sep 2010 05:29 PM
Is there a recommended spacing, and pattern ?  At what point would the number of penetrations by the screws weaken the osb?
29 Sep 2010 05:45 PM
Posted By Stonelake on 29 Sep 2010 05:29 PM
I would slightly stagger @ 8" oc.         you would have to have a screw every 1/2" before it would weaken OSB
Again....Thanks so much!
People Online People Online: Visitors Visitors: 195 Members Members: 0 Total Total: 195
