Probably much smarter spent on doors/windows.
If you calculate your expected heat losses with the different insulating methods, you will be able to tell if that is true or not.
My first guess would be that with a radiant slab you do not want to UNDERinsulate from recommended. That could be reinventing the wheel, and is potential for a LOT of unnecessary heat usage.
