Wall framing - where to 'split' long walls?
Last Post 12 Jul 2013 10:15 AM by jonr. 7 Replies.
robert.thompsonUser is Offline
16 Jun 2013 07:58 PM
Hello:
My friend and I are about to start the 2x6 wall framing on a 30' x 40' house.
My concern is that the wall sections will be too heavy for us to raise.
My question: Is there a 'best practices' method for determining where to break the walls into smaller sections, for 2 people to handle?
Most importantly, are there certain places where we should * NEVER * split the walls?
Thanks for any advice on this topic.
Rob.
Rob.
http://googlevoiceforcanadians.com/
arkie6User is Offline
16 Jun 2013 09:13 PM
Most framers around here use 16' long lumber for top and bottom plates, so you should have a natural break at 16', another at 32', and another 8' section.
17 Jun 2013 08:21 AM
The second top plate should not break at the same point as the first top plate.  Aligning the joint will build in a hinge in the wall and that will make the wall weak.  Missing the joint with the second top plate by at least 4' will make the wall stronger.
17 Jun 2013 09:29 AM
Any way you split it, be sure to lay a bead of acoustic sealant caulk or can-foam under the bottom plate just before you tip it up, for the best possible air-seal.
17 Jun 2013 09:44 AM
Thanks people! :)
Just one last question, I hope, on wall framing:
Should I continue the bottom plate across my door openings and cut them out after the wall is raised?
Rob.
Rob.
17 Jun 2013 01:12 PM
Posted By robert.thompson on 17 Jun 2013 09:44 AM
Yes.  Most definitely.  Helps keep the wall straight.  Also, don't install your jack studs until after the wall is up.  That way you can use your circular saw to cut out the bottom plate (cut 1-1/2" inside the king stud), and you can set a nail/screw through the bottom plate right under the jack stud.
07 Jul 2013 12:23 PM
Update:
All the walls are framed, sheathed (OSB) and raised!
With the help of three 'wall jacks', three of us were able to raise the 46 foot OSB sheathed 2x6 (16" oc) wall (with all LVL headers installed and openings fully framed) with not much problem at all - amazing! The rest of the walls (the longest was 30 feet) were raised by 2 of us using 2 wall jacks - amazing!
Some pictures here.
Now we are waiting for delivery of the trusses on Tuesday.
Rob.
Rob.
Generally avoid caulk or foam for air sealing of wood and use rubber gaskets or high quality tape.
People Online People Online: Visitors Visitors: 230 Members Members: 0 Total Total: 230
