Posted By arkie6 on 08 Mar 2014 05:17 PM
And you can cover the rigid foam insulation with a 1x2 (if using 1" thick foam) or 1x3 or 1x4 (if using 2" thick foam) PVC trim board such that the top of the PVC trim is flush with the top of the concrete. This will protect the foam from physical damage. You can buy this material at Lowes or Home Depot.
Any architectural details you can upload or link?
Would the EPS thermal break take place right at the threshold area or just below the step down where the concrete patio meets the interior slab?
