3/4 inch form ply used to form the basement then as sheeting on roof...opinions?
Last Post 08 Apr 2014 07:04 PM by christpuncher. 8 Replies.
brownhomeUser is Offline
01 Mar 2014 10:38 PM
looking to build my first house... I pour concrete floors/walls for a living and want to stretch my money. I work for a big company and using there forms isn't an option. I heard of forming the foundation with 3/4 form ply and then using it on the roof. anyone ever do this or have any suggestions. thanks
ICFHybridUser is Offline
02 Mar 2014 01:28 AM
That's pretty stout roof sheathing.
02 Mar 2014 07:54 AM
Posted By ICFHybrid on 02 Mar 2014 01:28 AM
Yes, that is stout roof sheathing but it is a good reuse.
02 Mar 2014 10:46 AM
I'd say you'd want to clean it pretty well as I've noticed even a little concrete residue seems to attract moisture hygroscopically, and you don't want that on the sheathing.
02 Mar 2014 05:09 PM
i figured that if they needed a quick pressure washer bath, that would work. i'm seeing big savings in this process. no rental on forms... just the difference on 1/2" osb would be big.
arkie6User is Offline
02 Mar 2014 08:45 PM
Are you planning on finishing and insulating the basement? If so, have you figured in the costs for insulation and compared the costs of a poured basement wall with insulation to Insulating Concrete Forms (ICF) that remain in place following the pour?
Also, are you planning on carrying those 3/4" sheets of plywood up onto the roof framing or will you be paying someone else to do it?  If someone else, figure on additional costs for toting that heavy 3/4" plywood up on the roof.
LieblerUser is Offline
02 Mar 2014 10:08 PM
If the soils in your area are suitable, consider using a wood basement. If you are planning on insulating the basement even to r10 it will cost less to use a PWF For less than the cost of the concrete alone you can easily have an r 30 basement with PWF.
03 Mar 2014 12:24 PM
The plywood will have a fairly high moisture content after being used as concrete forms folowed by a power-washing, but that's fine as long as you're not going to then seal in that moisture by insulating under the roof deck.
christpuncherUser is Offline
Why not use it as a subfloor?
Membership Membership: Latest New User Latest: IntegratedHomes New Today New Today: 0 New Yesterday New Yesterday: 0 User Count Overall: 35026
