As a builder new to ICFs, I wanted to generate some discussion on secondary drainage planes, or the lack therof, in ICF exterior finishes, and any attendant issues that creates. With stick construction, there should be a secondary drainage plane installed (building felt, Tyvek, Typar, etc) that handles any water that gets behind the primary drainage plane (the “siding”). All the window/door flashing should be installed “shingle style” to keep any bulk water moving down the correct plane and back to the exterior. EIFS/Dryvit, for instance has acknowledged the need for a secondary drainage plane, and their literature always shows one in an EIFS type installation.
There are numerous products available that indicate they can be installed directly over the ICF, e.g. Sto, Total Wall, Dryvit, Grailcoat, etc. This is of course an attractive proposition due to simplicity/cost/time reductions. The products mostly seem to advocate keeping the water out through chemistry (most are ‘waterproof’). None of the literature on the web sites indicates how water intrusion is handled when it actually occurs, which of course it will. In speaking with a Dryvit distributor, their explanation was basically that EPS and concrete can handle being wet and so it is OK. Not exactly the building science explanation I was looking for, nor one I feel comfortable with.
Is a high perm level sufficient to allow moisture to dry to the exterior? Sto, for instance, has a vaper permeance of 34. (I haven’t talked with Sto yet to see if this would be their explanation) Dryvit Residential lists a perm of 7 and so would dry much more slowly.
The block I am looking at (AMVIC) has vertical channels every inch or so. Can/do these channels function as a drainage path even after receiving a base coat?
Has anyone done the traditional 2 paper coat/metal lath in conjunction with one of these 2 coat systems?
JD Hanson
