floor systems for ICF construction?
Last Post 21 Apr 2007 04:08 AM by Bakhtiyari. 4 Replies.
mcrockfishUser is Offline
15 Apr 2007 04:40 PM
who has a good floor system. My historic building will only have floor to ceiling heights of 8'8". I need to run high efficiency HVAC air ducts, lighting wiring, etc... Which company offers the best flooring system to complement the walls?
James EggertUser is Offline
15 Apr 2007 05:07 PM
Your question as presented probably cannot be answered. I suggest you have your designer or archie evaluate the systems out there, to see how they could work for you. I base this on your comment about 8'8" between floors, but you don't say how thick you can build the floor platform(s).
icfcontractorUser is Offline
15 Apr 2007 11:35 PM
McRockFish,
Once again Jim is right more information is needed. If depth of the floor is a concern then a precast floor may be in order for they are 6 to 8 inches thick. Dending on your spans wood I-joist, steel I-joist with concrete slab, and cast in place concrete slabs all use 10 to 18 inches of space.
ICF Contractor
16 Apr 2007 10:38 AM
I did notice the high efficiency ductwork comment, and wonder also which system is planned at this stage?
The inclusion of a high-velocity system may solve the cooling issue, and you could use a hot water based heating system, which may be a little more "authentic"?
Gee, what was used for heating in old historic(or repro) buildings?
BakhtiyariUser is Offline
As Jim said many factors should be considered. However I can recommend you to see also the "Prescriptive Method for Connecting Cold-Formed Steel Framing to Insulating Concrete Form Walls in Residential Construction"
Prepared by: Building Works, Inc., Cambridge, MA, Contract H-21311CA,
February 2003.
May it helps as an idea.
People Online People Online: Visitors Visitors: 168 Members Members: 0 Total Total: 168
