I have designed concrete floor slabs using various types of joists.
I have heard complaints about the bounce in the concrete floor before the completion of the whole job. Personally I believe that once the flooring is installed, the partition walls are in, all the architectural appurtenances are in, and the funiture is in, the bounce will not be noticed, or at least it would not be found to be objectionable. During structural design, one should also look into the length, and width of the floor panels, the thickness of the slab and the associated properties of the supporting structure to avoid resonant frequencies.
