Trouble with Windlock 2 QC hotknife
Last Post 02 Jul 2007 08:00 PM by walltech. 7 Replies.
ICFfamUser is Offline
01 Jul 2007 09:58 AM
I was using a Windlock 2QC hotknife with a standard blade using perhaps a total of 5" of blade material (just cutting groves 2.5" deep, 3/4" wide for romex.  I was busying grooving with it, and then it stopped working.  I noted that the blade was sort of gunked up at the connection to the knife, so i used some sandpaper to clean up the blade, reinstalled it, and was working well once again.  This happened two more times (which I later realized was being caused by me using the connectors of the blade as a depth gauge against the foam), and then cleaning didn't work.  The unit was just inoperable.
I called Windlock, who promply informed me that the knife was under warranty.  They even sent me a replacement loaner knife while I waited for mine to be looked at.  When the loaner came, I immediately noted that it didn't seem to get nearly as hot as the previous one - the blade used to glow orange when the unit was on (thereby making the cutting of the grooves go quickly).  I also noted that it stopped working after maybe 3-4 minutes of use, but if you waited a few minutes (I guess for it to cool down), it worked once again.
Then I had a need a need for a much deeper grove (installing some IC can lights in the "ceiling" of my LiteDeck garage floor).  I determined that I needed a groove 13" wide by 9" deep or so.  I took some plumbers tape, bent it to the proper configuration, cut it down narrower so as to fit into the slots provided by the knife, and turned it on.  It hummed louder than usual when on, but the plumbers tape eventually heated up and I was slowly (like very slowly) cutting through the foam.  I stopped after a few seconds, cut a smaller version (perhaps 6" wide by 4" deep), and had much better success.  Thinking that the core issue with the slow going with the longer plumbers tape was simply too much resistance, I then had the idea to use 12AWG solid bare copper wire to make my configuration, thinking that Copper was a better conductor than the galvanized strapping.
I cut a smaller section yet, albeit only slightly smaller, connected it to the knife, and turned it on.  My GFCI outlet immediately tripped.  It, in fact, didn't just trip, it died - nothing I could do would make it work again.  Remembering that the GFCI outlet was in fact a Harbor Freight Tools special and possibly of lesser quality - this was my first use of a HF GFCI, but I haven't always seen the best quality from their tools), I replaced the GFCI with another duplex receptacle (this time, a non-GFCI commerical-grade 20A version since I didn't have a GFCI non-HF receptable available), and went to work.  What a difference!  The copper wire worked famously as a "knife".  I cut for perhaps a total of 10 seconds, placed the knife down for a few seconds, went to use it again, and found it to be inoperable.  Great...so now I broke a SECOND hotknife.
Am I using this tool incorrectly somehow?  It seemed at the time that the GFCI shouldn't have been able to trip since it is, after all, a GROUND FAULT circuit interruptor and the Windlock knife is only fitted with a two prong plug.  Now I wonder if it "took the bullet" for the knife and me just changing out the receptacle forced the failure of the knife.  The knife strikes me as not much more than a glorified toaster, but perhaps there is something more going on here.  Any ideas?
walltechUser is Offline
01 Jul 2007 12:01 PM
We have had 2qc last for years as rentals and never had problems with them. It sounds like the lack of the sled is causing the gunk up problem that's leading to failure. Also it sounds like your using a straight blade to cut the romex grove? That's allot of blade to heat up and they cut slower than the bendable blades. We design our own bend ables that cut 2.25" deep and they taper from about a 1/2" to 1/4" in that length. This allows you to push the romex into the slot with a standard screw driver and as it enters the bottom of the grove its friction fit.
As far as the larger path you tried to cut that's way to much for the QC, the super-groover could possibly handle it but that's a job for the electric chain saw.
Dave
James EggertUser is Offline
01 Jul 2007 12:09 PM
I have had zero problems with my two hot knives. I also use the smaller and bendable replacement blades!
02 Jul 2007 01:17 AM
I suppose the question is why is it that you feel that the path I tried to cut is "way too much" for the QC. If it was, I would have expected it just to not warm up the metal to allow a cut to occur, not have it fail. How do you know how much is too much?
02 Jul 2007 01:18 AM
I suppose the question is why is it that you feel that the path I tried to cut is "way too much" for the QC. If it was, I would have expected it just to not warm up the metal to allow a cut to occur, not have it fail. How do you know how much is too much? Wiould you have expected the tool to fail if used in this way?
Cattail BillUser is Offline
02 Jul 2007 03:56 PM
ICFfam
I to have had 4 of the 2-QC knives for over 5 years and let my electrical contractor borrow it on a regular basis.
The easiest explanation is that the equipment is designed to be used with the blades provided , you would not take your wifes suv and tow a trailer with a D9 cat on it would you, not trying to be rude just trying to point out that equipment is designed to do so much and no more.
eric monkmanUser is Offline
02 Jul 2007 06:45 PM
I bought a Windlock Hot Knife , and the unit came with specific instructions that it was for intermittant use only.
The Groove Jet can be used without pause, so it gets the bulk work. The Hot Knife is a toy by comparison.
Nothing beats an electric chainsaw for wiring ICF, however, and its very cheap to purchase.
Also the foam fumes turn me off, so the chainsaw wins on 2 counts.
ICF fam, it's something we all have learned over time. If your still at an early stage invest in a electric chainsaw to finish the job.
Maybe you can sell your replacement to a local contractor down the road.
dave
People Online People Online: Visitors Visitors: 410 Members Members: 0 Total Total: 410
