Wanted: straight talk on the termite issue
Last Post 18 May 2015 09:14 AM by smartwall. 79 Replies.
Page 3 of 4 << < 1234 > >>
jeepsterUser is Offline
12 Jul 2011 08:00 AM
I still wonder how termites can get into your home. I guess I'm ignorant about termites. If you have your ICF blocks on a footer/slab, which travels the perimeter of the house, how are the termites getting to the interior? Do you only have an ICF basement and are they tunneling up through the foam to the wood structure, then back down to the basement?
kbaUser is Offline
12 Jul 2011 09:16 AM
The termites are tunneling through the foam, which they initially accessed below grade just above the footer.  In our case, they tunneled all the way up the ICF wall until they found wood, which was in the ceiling of the garage.
galnarUser is Offline
12 Jul 2011 10:04 AM
Do any of you have experience with Sentricon or one of the other proactive outdoor termite prevention systems?
mhallUser is Offline
12 Jul 2011 04:41 PM
We have no experience with Sentricon. We were talking with Terminix about doing the treatment, so we got the sales talk and it sounds great, but then realized that they were assuming we had a Superior wall ICF house. When they realized that it was Reward, they walked away. We are in Western North Carolina and have had no indication that we have a termite problem, we are trying to be proactive. Has anyone identified an exterminating company that will do termite treatments on Reward wall homes? We have a finished basement, so our foam is below grade on 2 sides.
12 Jul 2011 06:01 PM
Posted By kba on 12 Jul 2011 09:16 AM
Do you have foam under the slab?  If you dont', then that's what I don't understand.  The basement slab should be resting on the inside edge of the footing.  I know termites are small, but I never thought that they could fit between a concrete slab and a concrete footing.  If this is the case, there's not much hope for a traditional wood-built home.
12 Jul 2011 07:15 PM
Termite company personnel told me that a termite can get through a crack that is 1/32" wide. But I do not think they can get through concrete unless there is a crack.
kbaUser is Offline
12 Jul 2011 09:41 PM
It's not a basement slab, it's a garage slab, and it's outside the envelope of the ICF walls.  The garage slab is at grade, a good bit higher than the footings.
Regarding an exterminator in North Carolina, we used Walt Cooper of Cooper Pest Control in Raleigh.  I doubt that he'd go to the western part of the state, but he might have some recommendations.  He's treated several Reward ICF homes for our builder, Greg Carlyle.
12 Jul 2011 11:33 PM
Alton,
My concern is that they could go into the outside layer of foam, up to the wood (window, door), then into the sheet rock.
danpitneyUser is Offline
19 Oct 2011 07:58 PM
Posted By Alton on 24 Apr 2011 04:42 PM
Although borate treated EPS may not be the answer to defeat termites, I am happy that someone conducted extensive experiments to determine what would work.  Now instead of saying "borates" can we all say "Deltamethrin"?  I think it is easier to say BLUEGUARD™.
Resurrecting this thread the latest thing for treating EPS foam during manufacture seems to be imidacloprid also known by the trademark Preventol. I have no idea how well it works but it is supposedly very compatible with EPS, does not reduce the foam's strength, every EPS bead is supposedly coated with it, and of course it's deadly to termites. Some of you may recognize that imidacloprid is also the active ingredient in the termiticide for treating soil known as Premise. The Logix TX series has imidacloprid, does anyone have experience with this yet?
JustOneMomUser is Offline
12 May 2015 11:54 AM
We have PolySteel and we just discovered termites inside when we were replaced some baseboards... Going to remove drywall above the infestation tunnels to see if they made it to the ceiling joists...
skia_dUser is Offline
12 May 2015 02:39 PM
Sorry about your troubles, JustOneMom. Can you give some additional details, such as: When built? Where built? Type of waterproofing used? Below grade, or ICF blocks on slab-on-grade? Any termite treatment done at any time? What kind? Were the blocks treated with borate or anything else? Extent of damage?
Thanks.
12 May 2015 02:58 PM
It's hard to believe almost 8 years has elapsed since I made the original post. The answer to my question is more than obvious by now, and it's obvious the industry as a whole has come around to accepting that termites definitely can be a problem with ICF structures. Two articles for those interested: http://www.nachi.org/icf-termite-inspection.htm and http://www.icfmag.com/articles/features/myths_vs_reality.html
12 May 2015 04:32 PM
Built 15 yrs ago in NM, half on concrete slab, half below grade basement and there were 3 layers of waterproofing materials used, ground was pre-treated for termites. The ICF blocks were, not to my knowledge, termite resistant.
12 May 2015 05:22 PM
In termite country one must install a stainless steel mesh between the ICF stem wall and ICF house wall. The mesh breaks the EPS and termites cannot tunnel through the mesh. A synthetic parge coat should also be applied to the ICF. This should be a mandated detail in termite areas.
In addition, using termiticide around the foundation is necessary as part of an on-going treatment. Poly vapor barriers should also be used under the slabs. Termites can't tunnel through poly.
Make no bones about it, termites can and will tunnel through EPS foam, borate or no borate treatment, they can and still will tunnel through it.
icfboundUser is Offline
13 May 2015 08:05 AM
Lbear, can you please post a photo or illustration of this SS screen and who manufactures it.
CONservative: The first three letters are all you need to know to fully understand this Republican.
<br /> <br />
Racist: A person who believes their race is superior to another race.
<br /> <br />
Religion: The deception of suckers who fear nonexistence to believe in a nonexistent supreme being and to adhere to false doctrine to control and exploit them.
<br /> <br />
Republican: A greedy, racist, sexist person who skillfully uses deception, hate, fear and religion to control and exploit suckers to gain personal wealth and power to benefit themselves while using government to limit the freedoms, safety and pursuit of happiness of others.
<br /> <br />
Sexist: A person who assaults, discriminates, intimidates or stereotypes the opposite sex.
<br /> <br />
Sucker: A weak minded person who has been brain washed and who usually lacks education and critical thinking skills allowing them to be easily deceived. <a href="https://www.youtube.com/watch?v=vGAqYNFQdZ4">Watch...Don't Be a Sucker!</a>
<br /> <br />
Trumpian: A narcissistic and skilled con artist Republican who is highly attractive to suckers and uses Fascist and Nazi tactics and commits traitorous acts to undermine democracy to gain personal wealth and power.
13 May 2015 12:17 PM
One company calls it Termimesh. See: http://www.termimeshusa.com/aboutUs.cfm
13 May 2015 06:22 PM
Alton provided the link for the product. It is a stainless steel mesh that termites cannot tunnel through.
13 May 2015 07:19 PM
Can this product be retrofitted into existing walls? Or applied to the exterior of the foam?
richmUser is Offline
14 May 2015 12:01 AM
JustOneMom, If you call the manufacturer I bet they could give you the info you need. Good luck with the problem - they are persistent! RichM
14 May 2015 12:04 AM
Posted By JustOneMom on 13 May 2015 07:19 PM
Not really, this is inserted during the construction phase PRIOR to the concrete pour since the mesh is embedded between the foam on the stem wall and it sits partially inside the concrete core.
To retrofit it would be a challenge. One would have to get to the concrete core in the ICF wall. There should be better alternatives in retrofitting but I don't think this mesh would work on a retrofit.
People Online People Online: Visitors Visitors: 297 Members Members: 0 Total Total: 297
