Swimming pool walls out of ICFs
Last Post 04 Jul 2013 10:38 PM by Alton. 58 Replies.
Page 3 of 3 << < 123
03 Jul 2013 05:12 PM
That quote is in the paragraph about spacing and evidently doesn't apply to the lift rate. But no doubt that if you go all the way to approximately zero slump (SCC), you don't need any vibration. They should be more precise and give a full table of slump vs vibration needed.
FBBPUser is Offline
03 Jul 2013 05:37 PM
Posted By jonr on 03 Jul 2013 05:12 PM
It talks about the sphere of influence. Just as the head effects an area wider in higher slump mixes so it also effects areas high and lower. So if the head is moving concrete 12" a head of it instead of 6 inches that means you can move at twice the speed.
Anybody that uses SCC in ICF must have a death wish!
03 Jul 2013 05:45 PM
My understanding is that the lift rate is based on how fast a bubble rises, not sphere of influence. Available information is pretty vague as compared to most concrete specs.
Midsouth ICFUser is Offline
03 Jul 2013 05:53 PM
banging on the wall does work, but it is not as effective. a small battery powered vibrator is the ticket. that's all you need and the mix is also very very important as stated above.
Ryan Gunn
Owner, Midsouth ICF Builders LLC
colinmccUser is Offline
03 Jul 2013 09:05 PM
Posted By Midsouth ICF on 03 Jul 2013 05:53 PM
  A small battery powered vibrator is the ticket. that's all you need and the mix is also very very important as stated above.
Where did you find a small battery powered vibrator? Googling just shows up the xxx sites!
If you have an URL I'd appreciate it.
scicfUser is Offline
03 Jul 2013 09:52 PM
Dewalt has one that has a 4' shaft. Makita has one with an 8' shaft.
03 Jul 2013 10:06 PM
They both have 4 foot shaft. no difference in them. I do know the Makita one can take beating.
Ryan Gunn
04 Jul 2013 08:56 AM
Thanks, I've found both now, the De-Walt is only 4 ft, Makita is available with 4 ft or 8 ft shafts.
I'm looking to buy the 8' Makita , BVR850Z 18V LXT, the best price I can find on the 'net is US $329.00 with no batteries/charger or $539.00 with 2 batteries and charger.
I run a Milwaukee only site so the batteries would be of no 'other' use, but will probably order one for the current Quadlock Job.
04 Jul 2013 10:12 AM
My guess is that the limited HP of a small battery operated vibrator means it has a small sphere of influence - gas powered would be a step in the other direction (more HP). But anything allows one to say "yes, we vibrated". What the world needs are clear ICFs.....
04 Jul 2013 10:44 AM
Posted By jonr on 04 Jul 2013 10:12 AM
jonr,
A clear ICF with plenty of R-value.  Not being able to see inside a finished ICF wall allows contractors to avoid vibrating.  A stiff mix and a lack of vibrating can lead to voids in the wall but the homeowner may never know.
Some of my projects have used ICF walls but now I am moving to walls with concrete on the outside where it can be seen and serve as the finish.  No reason to flame me.  Each technology has to stand own its own merits.
pjfUser is Offline
04 Jul 2013 11:01 AM
Question I have is, after you pour the walls and then pour the base, how do you take care of the gap between the two if you are not inserting a liner and are using plaster or some type of spray.
04 Jul 2013 11:02 AM
I agree, ICF isn't great for "trust but verify". Maybe one could put specs into a contract. Ie, slump, psi, pea gravel, HP and head size of the vibrator, spacing, withdraw rate, etc. Conservative values, not seat of the pants "it doesn't need much vibration because....".
FBBPUser is Offline
04 Jul 2013 11:21 AM
As discuss in a different thread earlier, there are a number of ways to verify the integrity of an ICF wall but if the homeowner/gc/engineer checks to make sure that the mix is right and that it is being vibrated they will avoid almost all issues. Stiff or waterery mixes need to be adjusted or sent back.
I personally don't see any use for a four foot wand on an eight foot wall. Are you going to cut ports in every other cell space? Even an 8' is not really long enough.
Alton - not to flame but ••• why let the outside temps into the wall when you can stop them on the outside face? Might not be as big a deal for you as for me with our different design temps but I think in any climate using the mass to your advantage makes sense.
04 Jul 2013 11:26 AM
Stiff ... mixes need to be adjusted or sent back.
Just add water :-)
04 Jul 2013 11:33 AM
FBBP,
I agree with you about using the right mix and proper vibration.    Lately, I have found a few contractors that are willing to vibrate walls and pay extra for a better mix.  I am finding that fly ash is a great ingredient to add to the mix.  Among other things, it makes the below-grade walls more water resistant and also eases pumping pressure.
I also agree about not letting outside temps into the wall and about using mass.  One technology that I have found that works well in my climate is SCIPs.
pjfUser is Offline
04 Jul 2013 01:09 PM
Question I have is, after you pour the walls and then pour the base, how do you take care of the gap between the two if you are not inserting a liner and are using plaster or some type of spray. Or some people might call this a cold joint. Anyone?
ICFHybridUser is Offline
04 Jul 2013 04:50 PM
Is that something you found on your projects or something you learned somewhere else?
I'm a big fan of fly ash - it really helps ICF mixes.
04 Jul 2013 06:57 PM
Fly Ash or Slag, whatever is available in your area
pjf
Use a waterstop, preferably a 6" piece, 3" into the slab/footing, the other 3" into the walls
as well if the finishes are done correctly you should not have any water intrusion/escape at the joint, but it can happen so use waterstop
Posted By ICFHybrid on 04 Jul 2013 04:50 PM
I have seen mixes with fly ash flow better.  I understand that the shape of fly ash particles act like ball bearings to reduce friction during flow.  Technical literature speaks about how the small particles of fly ash fill in the voids between larger particles to make the concrete more water resistant.   Fly ash can replace some of the cement.   Ready mix companies in my area can include fly ash in their mixes.
Here is a link to a short article about fly ash in concrete:  http://flyash.sustainablesources.com/    A quick google search will reveal many more links.
People Online People Online: Visitors Visitors: 450 Members Members: 0 Total Total: 450
