I used Polyguard waterproofing membrane on my ICF basement. I believe it was XT650 with termite protection. After partial backfilling I discovered that the back wall, non sun wall, the membrane had peeled down to the level of the backfill. My question is, does anyone know of an adhesive I could use to put the membrane back on the wall that comes in quantities less than 5 gallons. Polyguard only sells it in 5 gallon buckets and the cost is $125 plus shipping. Also, be advised that the wall is 36 feet wide and the membrane is essentially all one piece now so will have to be lifted all at once when I do put new adhesive on the wall.
If anyone knows of an alternative product would you please inform me.
Thank you very much.
