Dry in basically means Roof On and Windows In
A dry in or as I call it a shell contractor
Plans (either you or the contractor) Layout Excavation Footings/Foundation U/S Rough in's and slab Floor system Waterproofing and drain system Backfill/rough grade Wall System Roof System - prior to shingles get all pentrations installed (plumbing, electrical stack (if needed), bath fans, kitchen range hood, HRV, etc. anything that is going through the roof) Windows In
Or some deviation of the above
each contractor you deal with may have a more or less extensive list
After that you complete plumbing R.I., electrical R.I., HVAC R.I., Drywall, Trim, Paint, Flooring, Cabinets, then final trim/plumbing/electrical/HVAC and final paint touch up
