Do you need vapor barier around window bucks
Last Post 12 Mar 2008 02:38 PM by FlaICF. 2 Replies.
goofydhUser is Offline
12 Mar 2008 01:29 AM
Just wondering if i need a vapor barier around my window and door bucks. Do I have to use acoustic seal also. This is a house in alberta.
12 Mar 2008 02:47 AM
I've never put it on or been called on it by an inspector in either Ontario or California
I would use flashing on the outside and caulk the window in, then low expansion foam for insulation
FlaICFUser is Offline
We use acrylic waterproofing membrane systems to bridge foam and wood and wrap PT 2x's prior to installing windows or any exterior finishes. It is a must here in FL to make sure we don't leak. Not a true "vapor barrier" but a waterproofing detail. GR
