Posted By Tim S on 07/27/2009 5:46 PM
- Putting peel/stick flashing over the termination strip to better blend it with the foam above before putting on Tuff II
- Using real stucco so we can build it up over the strip (although I've never done stucco - the instructions for the Tuff II seem pretty simple).
You'll want to make sure the Tuff II will stick on the P & S. Otherwise that may be workable approach. A call to Styro Industries should get you an answer. I opted against real stucco because of no experience applying it. I sprayed the Tuff II. Not a piece a cake, but quite doable for a DIY, IMO. If you have any questions after reviewing the thread below, don't hesitate to ask.
Check out this thread to see how I handled this same situation using Tuff II.
http://www.greenbuildingtalk.com/Forums/tabid/53/view/topic/forumid/4/postid/44303/Default.aspx
Here's a pic of what some of it looks like today. Hot weather is making it difficult to get the lawn growing good!!!
