Foundation coating / termination strip
Last Post 27 Jul 2009 09:20 PM by sgo70. 3 Replies.
Tim SUser is Offline
27 Jul 2009 05:46 PM
First post.  Thanks for the all the good info shared on this site.
We're in process on our ICF home.  ICF walls are poured - very happy with results.  Some backfill is done but we wanted to put the foundation protection on before we finish backfilling.
We have Buildblock walls and used Polyguard waterproofing with a termination strip at the top to hold the top of the sheets.  We had taken the waterproofing a few inches above grade to ensure protection.  From information on this forum I was considering using Tuff II for protection between grade and the siding.  But the Tuff II is a thin coating so it will not hide the termination strip.
Since the termination strip will be visible under my current plan I was looking for suggestions on what to do.  Ideas I had include:
  • Raising my grade 8 inches (not real desirable).
  • Removing the termination strip and putting the Tuff II a couple of inches over the top of the sheets.
  • Putting peel/stick flashing over the termination strip to better blend it with the foam above before putting on Tuff II
  • Using real stucco so we can build it up over the strip (although I've never done stucco - the instructions for the Tuff II seem pretty simple).
Thanks for any suggestions.
smartwallUser is Offline
27 Jul 2009 06:00 PM
Termination strip should be just below grade.
27 Jul 2009 08:22 PM
Posted By Tim S on 07/27/2009 5:46 PM
You'll want to make sure the Tuff II will stick on the P & S. Otherwise that may be workable approach. A call to Styro Industries should get you an answer. I opted against real stucco because of no experience applying it. I sprayed the Tuff II. Not a piece a cake, but quite doable for a DIY, IMO. If you have any questions after reviewing the thread below, don't hesitate to ask.
Check out this thread to see how I handled this same situation using Tuff II.
http://www.greenbuildingtalk.com/Forums/tabid/53/view/topic/forumid/4/postid/44303/Default.aspx
Here's a pic of what some of it looks like today. Hot weather is making it difficult to get the lawn growing good!!!
sgo70User is Offline
Dmaceld-that looks like it would work for me with my old foundation and the 2" XPS. I wanted to add dimpleboard but I couldn't figure out how to have the insulation go right up to my siding and still attach DB below grade. Thanks for the pictures, Sean
People Online People Online: Visitors Visitors: 221 Members Members: 0 Total Total: 221
