Eliminating sills at roof connection
Last Post 11 Oct 2009 10:00 AM by dwangle. 13 Replies.
06 Oct 2009 10:50 AM
I am looking into eliminating the sill on top of the ICF wall and connect the roof trusses directly to the concrete. Embedding something like the Simpson Strong-Tie META or a pair of them look like the best option. What have you-all done?
06 Oct 2009 12:08 PM
Brad,
I have not done as you suggest, but I see no reason that it would not work with a proper connection. Just a word of caution, if you are using wood trusses, make sure to provide a capillary break between the trusses and the concrete to prevent moisture problems later on.
06 Oct 2009 12:31 PM
They have steel plates, some of them embed themselves further increasing the strength. It is probably worth the extra dollar and would serve as a moisture protector. But would moisture really make it to the top of the wall?
tdbuilderUser is Offline
06 Oct 2009 08:00 PM
I will typically float the concrete off an 1 1/2" below the top of the forms so my treated plate sits inside the forms. This makes the treated plate and the forms flush.
06 Oct 2009 08:12 PM
td,
I used to do that but had problem getting green treated to all the same elevation. I like the idea of the energy efficiency of it, but it just wasn't worth the trouble.
I want to skip the sill to; make a stronger connection and keep it energy efficient. I figured I would use 12" pieces of 2x4 with the embed anchors temporarily attached and set them instead of anchor bolts. I would use a laser to get them at the right elevation and not worry about making the top of the wall pretty.
smartwallUser is Offline
07 Oct 2009 07:00 AM
I use Icf-Connect half the price of Simpson.
07 Oct 2009 07:14 AM
Smartwall,
You use ICF-Connect for roof truss connection? The Simpson META is only about $1, so it is only $1-$3 per roof truss.
07 Oct 2009 07:56 AM
I was comparing it to the icfvl and the fact that it does two jobs .
07 Oct 2009 08:04 AM
For floors the Simpson is less expensive because you need fewer, usually 1/3 as many. For roof trusses I question if the strapping plate of the ICF-Connect will reach over most energy wall trusses.
07 Oct 2009 08:18 AM
But you are not factoring in the cost of eliminating the rim joist and the labor and cost of the joist hangers. I did not know of the Simpson Meta bracket. If this does the same job why ask the question?
07 Oct 2009 08:25 AM
The ICF connect does not work for us for floor connection. We have to have the framer do the layout and ICF connect get in the way of the bracing.
For the roof trusses, I would like to know more. Have you used them for the roof trusses? How much is a set? Do you know the uplift and lateral limits?
tesla-was-rightUser is Offline
07 Oct 2009 09:56 AM
back in my day I use to take a treated 2x4 cut the width of the wall inner thickness. I set these at the elevation required and attached with winlocks. I then set a mud sill strap anchor next to each one. (Simpson HETA) These can be as long as you wish to attach alongside the truss and go over the top as well. I would predrill screws into the 2x4 so there would be grip to the fresh concrete although that is probably overkill. The 2x4 provide a level place to set the truss and it can be adjusted horizontally and then tacked in place. The strap provides primary attachment and uplift resistance. Yes, we had lasers back then.
mike morrisonUser is Offline
07 Oct 2009 09:45 PM
we like to use simpson LTA1 twice the up lift loads of A H1 orH2 for 1.50 to2.00 dallers when ever you can get away from thermal brigding its worth looking at
dwangleUser is Offline
You can use either ICF connects or Simpsons. I usually recommend that for ICF houses. You can get that strong connection right to the concrete. That's my two cents worth.
ICF for life
People Online People Online: Visitors Visitors: 220 Members Members: 0 Total Total: 220
