4" for Small Pumphouse
Last Post 30 Oct 2009 11:22 AM by Baldwin2012. 1 Replies.
FarmboyUser is Offline
25 Oct 2009 12:29 PM
Considering 4" block for a 4.5' x 6.5' (interior) well pumphouse.
Walls would rest on 8" thick footing, the bottom of which will be 32" below grade.  The interior floor of the pumphouse would be a floating 4" concrete slab over a backfill of crushed stone/sand and 6" below grade.
Since the interior and exterior backfill will balance lateral forces, does anyone see a problem with using 4" below grade?
The Logix tech guide shows 4" can be used for crawl space walls no taller than 4'-10".  This will be 5 courses of block or 6'-8", of which 2' will have interior and exterior backfill.
I plan to use #4 rebar:  vertical @18",  horizontal @16".  Thanks Dave
Baldwin2014User is Offline
yeah its fine.
People Online People Online: Visitors Visitors: 259 Members Members: 0 Total Total: 259
