Bracing short walls (4' or less) ?
Last Post 04 Jan 2010 07:43 PM by TB MACS. 11 Replies.
MT_ICFUser is Offline
29 Dec 2009 12:17 AM
I have only poured walls 8' or higher which obviously is easy and very effective to brace (I have used Hilltop systems and now own Reechcraft 8' bracing).  Does anyone have any two cents about bracing 4' walls?  I am doing a 4' pour (crawlspace) followed by an 8' pour on top for an upcoming job and it is crucial that the 4' ICF foundation be perfectly plumb and straight (270 LF).  It has been suggested to me to brace it will 2x4's diagonally around the entire wall system and adjust it by hand after pouring (2 lifts).  I am a little skeptical that will be effective, and not a safety risk when making adjustments.  Any input would be greatly appreciated. THanks!
smartwallUser is Offline
29 Dec 2009 07:19 AM
Use the internal bracing system that many icf companies sell. It will give you straight walls on a four ft. pour. Also attach your ledger board before the pour and brace with 2x4's.
vermonticfUser is Offline
29 Dec 2009 06:43 PM
Sting it then use one continous 2x4 braced every 6 feet inside and out if you are worried.
Add if you do put your ledger in prior to the pour which you obviously should that will keep everything very square. If you pour 8' walls this will be no problem
29 Dec 2009 07:40 PM
why would you put the ledger (Im assuming rim joist) on before the pour? I generally place my Simpson ties in the ICF, pour concrete, and then lazer a level line and attach the rim joist to the Simpson ties... that seems like it would be the best way to guarantee a level floor that is hanging off the rim joist on the inside of the ICF wall
29 Dec 2009 07:47 PM
On 4' frost walls we put on the Reechcraft strong-backs horizontally, approximately level with grade. Then we put two or three turnbuckles per strong-back for adjusting.
30 Dec 2009 06:25 AM
You screw your rim joist into the web with simpson bracket behind it. After the pour you can relevel if needed and attach it with the other part of the bracket.
30 Dec 2009 08:46 AM
Wood is not as straight as an aluminum or steel strong-back.
30 Dec 2009 05:47 PM
Thanks ICFconstruction, thats what I was after, I will either do it the way you suggested or just brace normally as I would on a taller wall.
arkie6User is Offline
31 Dec 2009 12:13 AM
I would think with only a 4' high wall that you could internally brace it at the top with wire ladder type reinforcement, externally brace the corners well with 2x lumber and kickers, and run a tight nylon string line along the top outer edge of the forms. Nothing is going to be straighter between point A and point B than a tight nylon string. Then all you would have to do is push or pull the top of the wall if needed during the pour to insure it remained aligned with the string. And if you start with the forms properly aligned with the string prior to the pour and the footings are good and level, little if any adjustment during the pour would likely be required.
31 Dec 2009 06:45 AM
Ideal project for a mono-pour.
thagreenUser is Offline
04 Jan 2010 11:08 AM
Vertical 2x screwed to the blocks with spacing as a 8' wall would need complimented by a diagonal well anchored to the ground and string line on top of wall will give you plumb walls no problem. We just did so about two months ago and all is well. Plumbness was very important since we added 16' above the frost wall. There shouldn't be much compression since it's only 4'.
Good Luck!
TB MACSUser is Offline
Once we level and foam our walls to the footings, we attach a 2X horizontal around the top course. This will allow you to attach your turn buckle to the wall and adjust in or out to string lines pulled from corner to corner. We also use turn buckles on corners that have long walls so they dont push.We adjust walls before pour and only attach turnbuckles if needed, after placement of concrete laser level the top, check corners for plum, and attach turn buckles where needed to tweek wall.
TB MACS -------BUILDING THE CAROLINAS ONE BLOCK AT A TIME!
People Online People Online: Visitors Visitors: 379 Members Members: 0 Total Total: 379
