Posted By rigatoni on 01/28/2010 5:26 PM
The contractor said he usually only installs insulation under the foundation's slab if they install radiant floor heating, which I won't have. I'll see how much extra he wants for this extra insulation.
The reason for that is because of the temperatures involved. With radiant heating the concrete will be on the order of 80 - 85°F. Used as living space with warm air heating the room air temp will be on the order of 65 - 70°F. The ground under the slab will likely be around 55°F, which means there is not a very high thermal gradient through the slab. Heat will move to the ground from the slab, but when the slab is only 65 vs 85°, it's not going to be a great amount. If you are planning on using carpet, or some other floor material that is in itself somewhat of an insulator, you will have a lot less heat loss.
In the radiant heat forum I participated in a discussion about the value of crawl space and basement floor insulation. I came to the conclusion that with a crawl space temp as high as 100F the payback wasn't there for blue board thicker than about 3/4". I use the crawl space as the supply plenum for my heating/cooling system.
I suggest you do a search in the radiant heat forum for slab insulation. You may come to the the conclusion for your design it's not worth the cost. Dow blue board, or Owens-Corning pink board ain't cheap.
