Furring out ICF walls in basement?
Last Post 17 Jan 2011 09:53 AM by Johnnie34. 23 Replies.
woksawiUser is Offline
29 Nov 2010 05:40 PM
Hmmm  - that might answer which way we have to go then.  I am sensitive and have not found a spray foam that I tolerate even when they are cured (the flame retardant seems to offgas for a very long time) --- unless you/others have a recommendation.  I'm testing OSI Green series foam right now.
If can't find a spray foam, we'd have to fur out and run electrical behind wall.  If I can find one, we will definitely go with the Plastermax.    So ideas welcome.
TheGreenBuildingProductsUser is Offline
02 Dec 2010 08:45 AM
PlasterMax samples on their way to you. If anyone else would like a sample of PlasterMax or StuccoMax, please contact us directly at 877 904 8424 or email us Barrett Enterprises Inc [email protected]
rvalueUser is Offline
08 Dec 2010 07:32 PM
Don't fur those walls out just to run electrical. If they are not yet poured, use Plastilock boxes and conduit. Otherwise, grooving the foam with an electric chainsaw and shoving the wire in that groove holds quite tighly. It isn't necessary to spray foam the groove afterward, though some people are more comfortable with that.
Details matter!
Jake Vierzen
R-Value Homes
Grand Rapids, MI
616.299.3654
Johnnie34User is Offline
Posted By thagreen on 24 Nov 2010 04:54 PM
Finding the webs is not that difficult ,really. Buy a stud finder that you can adjust the depth and you'll easily find them. Have tried with drywall on with good results. Usually in 100$ range.
Yep, studfinder works great ! If you used Reward Wall it`s even better every 6`` OC tiestrips--1 1/2" wide - same strength as a 2x4 !
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
