Posted By smartwall on 24 Nov 2010 02:58 PM
Take a flat blade screw driver stick it thru the foam about mid wall. Give a twist if it penetrates, the concrete has not set enough. In cold weather you should pump a 2 or 3 slump and add mid range water reducer to increase flow. This takes 25% to 30% of the water out of the mix and gives you stronger concrete and faster drying.
HI,
That was great if your installed strong concrete will fast drying...what brand is that?
Can you shared with us here...?
