When is concrete cured enough?
Last Post 05 Dec 2010 06:48 AM by greencleaning. 7 Replies.
peterswetUser is Offline
23 Nov 2010 06:47 AM
Hello all Im pouring my second level this friday and want to coordinate my truss delivery Here in eastern Canada were a few deg on either side of freezing at this time of year and Im wondering how long I should wait before attaching my top plates and subsequent trusses? cheers P
23 Nov 2010 07:36 AM
Cover the top of the walls and I would wait about 36 hours. But even then I would wait a week or so before tightening your anchor bolts.
smartwallUser is Offline
24 Nov 2010 02:58 PM
Take a flat blade screw driver stick it thru the foam about mid wall.  Give a twist if it penetrates, the concrete has not set enough.  In cold weather you should pump a 2 or 3 slump and add mid range water reducer to increase flow.  This takes 25% to 30% of the water out of the mix and gives you stronger concrete and faster drying.
matteoUser is Offline
25 Nov 2010 08:42 AM
Posted By smartwall on 24 Nov 2010 02:58 PM
HI,
That was great if your installed strong concrete will fast drying...what brand is that?
Can you shared with us here...?
<a href="http://www.buildingmaterials.co.uk/Plasterboard.html">Plasterboards</a> | <a href="http://www.buildingmaterials.co.uk/Plaster-Walls.html">Plaster Walls</a>
okblockerUser is Offline
26 Nov 2010 05:04 PM
In general, concrete reaches it's maximum strength in 28 days. Concrete "never" stops curing.
However, in cold weather, if the top of the wall was not protected on the second or third night you could have suffered mild freezing.
I would wait as long as possible before I really cranked down on the anchor bolts. You should have no trouble working the top plate if you don't hammer on the anchor bolts.
29 Nov 2010 07:37 AM
If you pour with less water the concrete will be stronger and will dry faster. I've seen concrete poured in the winter that didn't dry for 3 months.
29 Nov 2010 11:33 AM
The pour went very well, The mixing plant used hot/warm water so the set up seemed to progress well
It was about 0 deg C that day here and I covered the wall with plastic, All seems good now
greencleaningUser is Offline
You footings may be pockmarked or if they are still in a form then they could be diluted, which will require longer for it to cure. So if you just poured the truss then you should be okay. I am more concerned about the temperature. It is going to be drop near to freezing in my area tonight and that will be detrimental to the concrete, which is why it is normally only poured in the spring and summer (concrete can only be poured at temperatures between 50 to 70 degrees Fahrenheit, as near as 73°F as possible). The goal is to keep concrete cool and moist so it gains strength slowly, but efficiently
Here's to you, your health and the health of your family. <a href="http://www.cleaningcleaner.com">Eco friendly cleaning</a>
People Online People Online: Visitors Visitors: 159 Members Members: 0 Total Total: 159
