This section describes the theory behind green building. Most of this is related to design, but some is about construction. It is intended mainly for non-professionals who are interested in Green Building, although others may find it interesting also.
While the intention is that the information here is quite detailed,
the level of detail is limited by the complexity of the topic. Those
seeking additional info should refer to the resources section as well as
the references scattered in the text. All the material contained here
is a compilation of numerous books, periodicals and websites.
Because Green Building is to a degree climate specific, not all
issues are applicable to all climates, and although an attempt was made
to make this document as general as possible, it is biased toward a cold
climate.
Construction Methods
No matter how a house is built, the structure of the house must accomplish three things:
1. Keep the weather out: it provides a continuous barrier between inside and out
How much it has to keep out the weather depends on climate: in a
tropical climate you may only need to keep out the rain, in the desert
only the hot or cold, but in most climates you want to keep out both.
U can read more here http://www.civilengineergroup.com/?s=%09Insulating+Concrete+Forms
