Posted By ICFconstruction on 31 Dec 2010 10:31 AM
If it is choice between complicated design and quality of the structure, why is there a question?
I asked this because of what Gregw said
"I know that the ICF is better but in a 950sf house, one ICF and the other using standard basement and EEBA advanced framing technique, (3" spray-on polyurethane). What kind of cost difference would there be and how long is the pay back. Opinions?"
If you know ICF is better but concerned about the cost difference, make it simpler, simpler is cheaper for all the trades that will work on the house.
Regarding payback for the homeowner, it does not pay for itself in the long run. You get the benefits of a safer, more comfortable home with little, if any, additional cost right from the beginning (unless you pay cash). That is because your mortgage is a monthly expense just like your utilities. And utilities costs will likely rise, whereas a fixed rate mortgage does not. Besides the energy efficiency is only part of the benefits, in my opinion number two or three.
