sharing my limited experience
Last Post 10 Aug 2011 09:48 AM by quaker. 95 Replies.
Chloe Taylor
| 06 Jun 2011 04:20 PM |
Posted By jeepster on 04 Jun 2011 09:11 AM
Last Thursday I poured my first ICF basement. This is my own house, so I get to live with any consequences. I'd say it went 85% OK. But honestly, I think it would have gone 95% OK if I didn't have the block rep that gave me crappy advice. I still have the next level to pour, and I don't think I'll invite him over.
Here is a list of things that didn't go so well:
1. Many of my walls are bowed in. One is
bowed in up to one inch, and yes, it's the wall that everyone will see
pulling up to the house. My rep came and cranked in those braces way too much. The theory is that the wall will flex to the outside and it's hard to pull the wall back into alignment. I originally had the level bubble favoring the inside line, but he loosened up those braces and said it's easy to push the wall into alignment. The
wall obviously didn't move that much, if at all. The pump truck operator (who used to build ICF houses)
said they pull the walls in a max of 1/2 inch.
2. We waited way too long to adjust those braces. When that
concrete starts to sets up, it's next to impossible to make those walls
move. I figured if I'd get one wall to move, it would be a 28' wall
with 4 windows and a 6' door opening. All my braces did was bend the rebar stakes when I adjusted the turnbuckles . . . I
decided to make a potentially dangerous move and I hooked my truck up to
the top of the middle brace with a chain and pull. Letting the truck
pull downhill in neutral didn't make it budge. Putting it in 2wd and
giving incremental gas until the wheels spun didn't make it move.
Finally putting it in 4wd and spinning the wheels got me about 1/4" of
movement. Mind you this wall was the wall with by far the least amount
of concrete. Long and short, waiting until the end of a pour to true
the walls was horrible advice. I asked him after the first lift if
we should plumb the walls, and he said just wait until we are done,
that was VERY poor advice. It's going to be a lot of work to make siding look good on that wall.
3. He told me to not bother tap conning the braces to the footing. I did anyway, but on about 5 braces where I had to move them because of window strapping interference, I didn't bother re-tap conning. Not tap conning the bottom of the brace allowed the brace to move
up the wall while adjusting instead of hinging on the footing. You simply
cannot expect #10 screws anchored into plastic to hold the brace against
a wall that weighs at least 40,000lbs. This was only an issue with the
braces that I moved, but it was poor advice, none the less.
4. Putting the rebar in the corners for the wing walls after the
pour was complete. I got one piece of rebar in. The rest I'll have to
drill because the concrete was set up too firm.
5. Lift
heights. The pour was 10'6" The first lift went about 5'; the second lift went about 4'6", and the last lift went about 1'. I feel this
was responsible for a lot of bulges. The mix was obviously wet and
coupled with the vibrator and the height of the lift, I'll have more
rasping and trimming to do than I think I should have. If you're going around the wall three times, might as well make the lifts shorter to relieve some of the pressure, right?
6. I didn't have any blowouts, but I almost did. Once corner end joint broke out about 2", but it didn't spill any concrete. My rep told me to simply spray foam the bottom course to the footing and that would be enough to hold back the pressure. That might be true if we were pouring shorter lifts, but it obviously wasn't at the lift height we were pushing. If the corners are the most susceptible, then go ahead and screw 2x4s to the footing to hold the form.
Things that I will/would do different:
Mind you that my footings were spot on and my forms were high-end. The type that click together (trying no to drop brand names), so given a do-over:
Pre-pour: -tap con braces to footing to prevent brace lift during adjustment -if you have a large amount of fill that you are staking the braces too, either go down to virgin earth or pour mini- pads for your braces. This would help prevent your stakes from bending. I had about 6" of fill above the basement grade, and it allowed the rebar to bend when adjusting the turnbuckles. I don't think this would have mattered, because my walls were too set up anyway. -Big one! Tilt the walls in no more than 1/2 inch.
During pour: -monitor the movement after the first lift. If there was no change, then have someone start plumbing the walls while the concrete was still fluid, or at least split the difference. - pour all the lifts 3-4 feet - if you need rebar sticking out of the corners for wing walls, do it once the concrete stiffens, but don't wait until the end of the pour.
I didn't want to pour without the block rep on site, since I didn't have any experience at it. He reportedly had over 50 pours under his belt so I was really relying on his advice. I think If I went at it alone with the education learned here and the advice from the pump truck operator, I wouldn't be writing this email and I'd be sitting happy with a pour that went well.
Thanks a lot for sharing in your experience, had a lot to learn from your posting..... |
| <a href="http://www.capitalsteelbuildings.co.uk">Commercial Buildings for Sale</a> |
eric monkman
| 06 Jun 2011 10:58 PM |
Posted By BrucePolycrete on 05 Jun 2011 11:42 PM Eric, my friend. Do the homework. Withstands over 1,600 lbs per sqft of lateral pressure. At 2,000 lbs, the testing machine broke. Nothing else comes close. This ICF functions on a scale that others can not even conceive of. Look at the pictures -- they don't lie. How strong is your preferred form? By the way, this wall as shown is 8 ft tall.
Bruce my friend, the Polycrete corners have no crossties....... therefore they are weak. Using an expensive aluminum strongback will aid the situation, but essentially I rate your product as an inferior 2nd generation ICF. How do you attach finishing systems to your block? Looks like your installers have to keep a saw set for 45 degrees as you have no propietary corners or "T's" 3rd Generation block designers long ago dropped these methods as they are time consuming, cumbersome, and a huge pia for 2nd and 3rd story work. I'll take Logix, Amvic, Nudura, Fox, Buildblock, Superform, Greenblock etc anyday over your dinosaur. Take another swig buddy. |
dmaceld
| 06 Jun 2011 11:41 PM |
BrucePolycrete
| 07 Jun 2011 07:15 AM |
Eric, old boy. Your knack for turning lemonade into lemons is truly breathtaking, but like a man with his shoes on the wrong feet, you have it exactly…. Backwards. The beauty of a system is not in its complexity, but its simplicity. The Polycrete corner system doesn’t need cross ties, because it has a steel structure inside the foam panel. When combined with the aluminum corner guide you are assured of a perfectly solid, perfectly plumb corner the first time, every time. Other systems (as you certainly know) require constant checking and tweaking to keep the corners plumb while building the wall and pumping the concrete. You set that corner guide once, and it will not move unless you hit it with the backhoe. It can’t. Laws of physics apply. Corners do not need to be mitered, but some installers like to do it that way because it is cooler than butting them. If you don’t know how to use a circular saw, you don’t belong in this business. Other ICF manufacturers went to molded corners because they had to – it was the only way they could get what is essentially a foam coffee cup to hold concrete. Remember, all those extra molded parts the other guys have like “T”’s and 90’s and 45’s are all complicated solutions to the simple problem that their form is weak. Polycrete doesn’t have them because Polycrete doesn’t need them. Finishing systems are screwed to a continuous horizontal 22 gauge galvanized steel fastening strip that is embedded in the foam panel every 12” on center, as is that corner guide. It guarantees a solid connection and simplifies the attachment of interior partition walls. And steel is a lot stronger than plastic. Eric, I appreciate the continued opportunities to explain the Polycrete system, but we’ve been over this several times already and you seem to be having difficulty grasping the concepts. I think you should continue using the systems that you like and spend whatever time is necessary to deliver the best job you can to your customers. See you in the next thread.
lzerarc
| 07 Jun 2011 09:19 AM |
Bruce How (if any) is your system different from vertical formed corners using metal corners, such as Hobbs? Your two concepts appear to be very similar in nature.
BrucePolycrete
| 07 Jun 2011 10:00 AM |
Overall, the Hobbs system is much more labor intensive than Polycrete since every component has to be assembled. I am also convinced that a flat wall system is the only smart way to build with ICFs. But with specific regard to the corner bracing, it does seem to use the same concept as the Polycrete corner. Once you set it in place, it is not likely to move unless a catastrophic event occurs. |
lzerarc
| 07 Jun 2011 11:38 AM |
each side is always claiming less labor intensive. It would be interesting to see how it really does shake out. I know Hobbs has that video showing a comparison, whether how accurate that is or not. Obviously that is comparing a more standard block. THey also claim less bracing and a stronger design. How that compares to your system with metal instead of plastic, it probably does not. However price wise, I also do not know how they compare. Hobbs also has a flat wall design you can use entirely if you do not wish to use their engineered design, "higher r" design. I still do not know what to think of the vertical vs horizontal design. It seems the horizontal guys sure think that is the best method, but most I have talked to have never tried the vertical design. Yet on the flip side, the ones that HAVE tried the vertical, prefer the vertical.... but at the end of the day everyone thinks they have the best system. It just makes the job harder for people like me trying to sift through all of the claims. |
BrucePolycrete
| 07 Jun 2011 11:48 AM |
Izerarc, If you're only going to do it once, hire a pro. Go look at jobs he has done before, talk to his customers, and let him decide what ICF to use. Your job is to make sure you have done the due diligence on the contractor/installer. Leave the construction to the pros. ICF construction is not a DIY project. As Jeepster can attest, you can't practice and screw up a few times with concrete before you get it right. |
lzerarc
| 07 Jun 2011 01:49 PM |
I have been on many a concrete pour, just not ICF. I have experienced people in this area lined up to help with it however, assuming I go the ICF route. I also plan on attending a couple pours before this one. No way I would even consider something like this if it werent from my construction background. |
BrucePolycrete
| 07 Jun 2011 01:52 PM |
You have my best wishes for success. |
Lilly of this valley
| 07 Jun 2011 08:00 PM |
People, I said that I did not want to get involved on this Forum when I posted looking for an installer for a commercial ICF, Well curiosity got the best of me and here I am. I do not get involved in residential construction. However I do understand construction and the various types of ICF. Polycrete is not your typical ICF it is a S.R.I.C.F.(steel reinforced) this is what makes it strong and straight. The reason I did not want to state my opinion is because you have to many closed minded post that do not understand what real construction is. I only get involved in commercial and yes I call myself a consultant But I have been in construction for over 30 years yes this make me an old broad in the industry. I have used and recommended many ICF's but will never recommend any other ICF for the BIG STUFF. I see Bruce seem to be fighting a battle with a few egg heads and I did not understand why some of the installers I have used with Polycrete are not on here and speaking out on his behalf. So I made a few calls and I got my answer. It is they don't want other installers finding out how great it is, how fast it is,how straight it is.... Now I am not an installer BUT have in the past and all I can say is you all are missing the BOAT and should be asking Bruce what he has that you can learn how to play the big boy's/girls game, While not having any issues. The next thing any of you who do not think this is a good SRICF should go wash the stupid off your face and understand every form has it's place. now this will likely be my last post. |
jeepster
| 07 Jun 2011 08:42 PM |
I discovered something else while measuring for floor trusses today. Notice the gaps between the corner blocks and the flat blocks. Those gaps weren't there before the pour. The hyd pressure in the walls really pushed the outer section of the corners out. The inner section of the corners look good. This is more evidence that either the slump was too high, or the lift was poured too high. I'm going with the lift was poured too high.
My rep said I only had to zip-tie the top block to the adjacent block. After this, I think it would be wise to either tie all the corner pieces to their adjacent blocks, or run some strips of wood from the corner pieces to the adjacent blocks.
The picture is kind of crappy, but I didn't bring my camera today, so I'm going off of general pics I took last weekend.
peterswet
| 07 Jun 2011 08:52 PM |
How much vibrating did you do? overvibrating can create alot of hydraulic pressure |
jeepster
| 07 Jun 2011 08:59 PM |
I had a 1" vibrator. I started by installing the vibrator head, then having my help turn it on, then I pulled it out. My rep said just leave it on and go in then pull it out. I don't thing that was good advice. The way I looked at it, that method vibrated the concrete twice as much as needed. So, yes, I think you are correct. I think vibration compounded the problem. But, I think if the lifts were shorter (3-4' max), and I inserted OFF and extracted ON, I wouldn't have had this problem. Also, if I would have reinforced the corners I don' think there would have been an issue as well. What do you guys do on the corners? |
dmaceld
| 07 Jun 2011 11:49 PM |
Posted By jeepster on 07 Jun 2011 08:42 PM
Based on my experience of building one house, I would say the leakage you see is not excessive at all. There are dimensional variations in the blocks from the molding process and they can move a little bit. The fact you say the inside doesn't show it, but the outside does, makes me think the blocks were slightly undersize on the outside. I used BuildBlock ICFs. My rep had been a Logix dealer before switching to BB. He advised me to use a lot of zip ties. I don't remember how many, but I'm thinking we zipped every three or four or so up and down, tying two ends together and to the web of the block below, especially at the corners. I still had some concrete water leakage like you have. And this was with small aggregate concrete, slump around 6", and vibration only under window bucks and other tight areas. We poured the 9' walls in two lifts, with maybe an hour or so between them, the time it took to go all the way around. ICF blocks are not 100% water tight. In this situation I think your performance expectation is too high. My advice, don't fret about it. The wall straightness is a much more serious problem. |
jeepster
| 08 Jun 2011 12:10 AM |
I guess I wasn't clear on my previous post. It's not the leakage that I was concerned with. As a matter of fact, the leakage I liked to see, because it made me confident that the concrete was consolidated in that area. Most of these squirts happened when the vibrator was run down the wall. The pics don't do it justice. The gaps at the corner blocks opened up about 1/4" or so, which made my outside corners bow out at mid-wall about 1/4" or so. It's visible when standing on the wall and looking down. So, in all reality, it's still a wall straightness issue that I'm commenting on. It's just on the z-plane and not just the x-y plane. I didn't use any zip-ties to hold upper and lower courses together. Since these blocks click together, I guess there's no need. Thanks for your comments. |
ICFHybrid
| 08 Jun 2011 02:36 AM |
I had the good fortune to have nothing less than a master craftsman for a sub on my first ICF pour. All of a sudden, just before the pour, string lines appeared everywhere and he used them to check everything repeatedly during the pour. 60 yards went in beautifully. The only hitch was where the another subcontractor opened up a corner of an ICF wall to tie in his panelized retaining wall and no one thought to reinforce the open ends. There was a minor blowout, but since the lifts were kept to about 2 - 2-1/2 feet it was easily repaired. I am very impressed with ARXX block -it appears to be simple, yet robust. Braces were Tapconned in and every hole in the brace was filled with a pin driven in at various angles. They looked like pincushions. |
peterswet
| 08 Jun 2011 08:11 AM |
Jeepster, I use Nuduras corner clips , they are the heavy gauge metal clips purposley designed to secure the block together, they do add to the cost but work very well and are fast , much faster than wire or zip ties.
The buldge on the seam between the block you are commenting on is something that one of the crew watches for and applys a quick plywood patch during the pour as for vibration technique , we leave it on continuously but fast in and slow out cheers P |
peterswet
| 08 Jun 2011 08:14 AM |
Oh and the buldge remedys quite well with a rasp , takes seconds really P |
jeepster
| 08 Jun 2011 12:43 PM |
Thanks Peter. Corner clips are a good idea. I think I'll get some before I build up the next level. Also, can you recommend a good rasp? Has anyone fabricated their own? Thanks, Sean |
199 |
199 |
