pouring grade beams instead of using engeneered wood beams
Last Post 15 Nov 2011 06:11 PM by randynh. 4 Replies.
randynhUser is Offline
14 Nov 2011 09:11 PM
I am planning a addition on the back of a 2 story colonial.  There will be a full basement, but the addition will be only one story.  The dimensions are going to be 26' x 26'.  Can I pour grade beams to hold the first and second floors of the existing house?  How bout pouring a grade beam to hold up the main floor of the addition (wooden floor).  the grade beams holding the house would have to be secured with a ledger board to the side of the concrete beam to hold the lumber.  What are your thoughts?  If I add a pilaster on each end of the beam and a spread footing under each pilaster. I have full confidence that I can build this.  I am just unsure of the engineering aspects of it.  Can I get away with no columns?
14 Nov 2011 10:14 PM
I would ask my engineer about using a frost protected, monolithic, thickened edge slab on grade - ie. no basement and no changes to the existing house foundation.
15 Nov 2011 04:40 AM
my house is a garage under. Intend to use the additional basement space as a garage. So I would like to preserve this as much as possible. I could simply buy pre engineered wood or steel beams and accomplish what I am looking for. I was just unsure of what others have done in this scenario or if anyone had tried using concrete as the beams in their house
15 Nov 2011 11:14 AM
Lots of buildings have with no problems. Some, like "Falling Water", get it wrong and need very expensive repairs.
That is a a pretty wild house. Don't worry mine won't be anything like that. I will have to do as many calculations as possible and them ask some of my college friends that are engineers
People Online People Online: Visitors Visitors: 250 Members Members: 0 Total Total: 250
